Question about Cuisinart DCC-1200 Coffee Maker
Can't make coffee
When i close the top and press the button for the coffee to brew, the beeping begins which usually indicates that the top has not bee properly closed. the problem is that it has been closed properly. HELP
  • 8,596 Answers
Make sure the charcoal water filter holder and all parts are sitting in their proper place. Remove and then put them back in place if needed. If it still beeps, unplug the coffeemaker from wall outlet for longer than 20 minutes, and you should be good to go again.
-Tha Mp3 Doctor
Posted on Feb 21, 2009
How do I program my DeLonghi DCM 485?
Hi and welcome to FixYa, I am Kelly
First you must set the clock. Page 6 of this pdf manual:
http://www.smallappliance.com/images/SmallAppliance/English/products/standard/DCM485.pdf
Then prgram per instructions at the bottom of page 6 and the top of page 7 of the same manual. I note step 2 is missing from the manual.....
3. Press the CLOCK button until the desired brewing time is displayed
(See "How to Set the Clock" section of the manual).
4. Press the ON/OFF button to confirm the automatic time selected.
NOTE: The display panel and the on/off indicator light will flash.
5. Press the PROGRAM button to return to the current time of day (the
ON/OFF button will continue to flash.) The brewing cycle will begin
once the set time is reached and the ON/OFF button stops flashing.
6. If you want to check the automatic time selected, press the
PROGRAM button.
7. To override the automatic brew function, press the ON/OFF button
and the coffee maker will start immediately. Press the ON/OFF
button again to switch the coffee maker off.
Thanks for choosing FixYa,
Kelly
May 21, 2011 | DeLonghi DCM485 Coffee Maker
I have a Kenmore Elite Coffee Maker, I press brew, the light flashes and then it beeps but does not brew.
gotta have the correct time set, also check auto brew timer. Coffee pots usually beep when they are done brewing and then when it's turning off, usually after a hour. Play around with timer (hrs. and min.)
Apr 07, 2011 | Coffee Makers & Espresso Machines
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
Farberware FCP512S coffee pot instructions
How to set the time:
Plug the unit in
Wait until the hour on the LCD starts blinking
Press the CLOCK button to set the correct hour
Press the SET button to switch to minutes
Press the CLOCK button to set minutes
Press the SET button to accept the time
***there is no AM icon, only PM***
How to program delay brewing:
Press and hold SET until the hour begins to blink
Press PROGRAM until you see the tiny bell icon on the bottom of the screen
Press CLOCK until you get to the hour you want to start brewing
Press SET to switch to minutes
Press CLOCK to get to the minutes you want to start brewing
Press SET to finalize
Press PROGRAM to activate. When the little bell is flashing, the coffee pot is set to go on at the desired time. While the coffee pot is on or in warming mode, there are vertical lines on the top of the LCD screen that shows you it is on. If you press the ON/OFF button, you can turn it off before the two hour keep warm cycle is complete.
Hope this helps
Sep 09, 2008 | Mr. Coffee ISX23
Cannot turn off alarm.
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
Hope this will help you.
/Mirran
May 09, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
10 cup cuisnart stainless steel & black coffee maker
The beep indicates numerous things. If the top lid is open, it will beep, if you try to depress the brew or timer buttons.There is a button next to the grinder unit, that gets depressed when you close the lid. Check the lid to make sure the tab on the lid hasn't broken. The beep also indicates that brew cycle has finished, although, that is supposed to be only 5 beeps.
Feb 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker won't start and just beeps when plugged in
The door on the top is not closed properly. When you open the top door(cover),you will see a button that is located on the top of the grinder cover. that is a switch that tells the coffee maker that the door is closed and can safely make coffee..please check that all parts are in place and top door(cover) is closed comepletly. good luck.
Aug 19, 2006 | Cuisinart DGB-600 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
111 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
