Question about Canon Powershot SD450 / IXUS 55 Digital Camera
E18-lens stuck out-not fully out-won't budgein or out any further
Tried taping, blowing, dismantling, looking at "pins" EVERYTHING!! being an amatuer when taking a part dont know whaT TO LOOK for, when turing dont know whether its good or not, PLEASE tell me there's an EASY method. reset button?? it does the whole beep beep beep then E18 then turns off. i did get impacted-lol-i dropped it while taking a picture.that night a little tipsy tried pushing it back it and now its stuck in and out-PLEEEEEEEEEEASE help me!! singlesweetnsmart28146@yahoo.com
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. As you've dropped it, you might need to start with Fix #7:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 10, 2009
  • CameraR
    CameraR Feb 10, 2009
    By #7, suggest slight tugs on the lens as you press the power button. You'll want to persuade the lens out into its full extension. Hopefully you'll reseat the internal guide pins in their guide slots in the process. Listen for the "click" as described in the blog, and immediately stop if you hear it to try the camera.
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
What does the error code "e18" mean on a cannon power shot a10 ?
"E18" seems to be a code related to and barrel extension problems. Its showing because of lens error or you can say stuck lens. Ok now the question is how its stuck? its happens when the lens not ready for work. Some how its not able to
stable his focus method. That's why its stuck. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.
Apr 06, 2010 | Canon PowerShot A10 Digital Camera
Canon Powershot a610 dropped, lens stuck half way, won't move, gives E18 whenever one puts it in the mode to take a picture, no view through lens. Is the camera toast?
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Nov 19, 2009 | Canon PowerShot A610 Digital Camera
E18 error on powershot canon
Hello there,
Sep 27, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
My canon 550 has a len error an saying E18!
Hello there,
Aug 29, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
My canon camers is suffering from the E18 error
Hello there,
Jun 30, 2009 | Canon IXUS V2 Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera got stuck
Hello there,
Mar 12, 2009 | Canon PowerShot S80 Digital Camera
My camera is a Powershot A80. Error E18? What does this mean?
Dear Cheuer,
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off or it may not even powe on.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a problem.
You can also try the following ;
1). Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it, hopefully, it should come back to life.
If still you have a problem, then
2). Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
3). If it is still stuck, please do ensure that you use fully charged batteries, now place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
If Still it does not start, try to
4). Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
5). Repeatedly tap the padded/rubber usb cover with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. Dont hit very hard please. you might damamge something else
The last solution is if you are good with small screws, then you could open and clean the lens barrel. I can guide you on that, but if you are hesitant then please go to the nearest Canon Service center.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18
Mar 10, 2009 | Canon PowerShot A75 Digital Camera
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Hope this helps, let me know if you have a proble.
You can Try the following also;
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
137 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
