Question about Craftsman 4 Cycle Blower/Vac
Using leaf vacuum as snow blower?
Can I use my leaf vacuum as a snowblower?
    Guru:
  • 449 Answers
Yes
Posted on Feb 06, 2009
Remove a news paper from impeller for snowblower ,craftsman 26
Is a dry newspaper if so get your garden hose and it and run the snow blower a little at a time stopping and using small crow bar with a curved nail puller on one end or anything that has something that can grap..pull the wet paper out small pieces at a time keep soaking and pulling..may take some time but it ell comr out...good luck
Nov 17, 2014 | Craftsman Snow Blower 26 In. 208CC...
We have a yardworks snowblower and when not using the wheels always lock up. how do you unlock them without turning on snowblower.
Had the same issue and found out that the wheels lock when the motor isn't running and the accelerator handle is engaged. I still had both handles tied down from transporting home and it rolled fine after they were untied. Hope that helps
Oct 21, 2012 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Toro snowblower wont start. seems like the fuel isnt getting into carb.how and what can i do
Reference your toro snow blower. does it start and run for a few swconds then die. if so It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now.
Oct 21, 2011 | Toro Lawn Mower With Toro Power Tools
My snowblower just started back firing,why?
Snow is melting on the engine and causing the spark wiring and/or magneto to short out...
Stop blowing snow and run the engine at a fast idle for awhile to dry off the motor...then it will work again..
heatman101
Feb 25, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Hello I have a 8 horsepower craftsman show thrower, the engine is stuttering I think it's because it is running on CHOKE. the lever is loose and I have no idea how to replace or tighten it. Help! snow is...
Hi, You will have remove the carburetor shroud and then check the linkages from the choke lever to the choke.
Unfortunately Craftsman does not give detailed parts listings for most of the motors on snowblowers on either their manual site, managemylife.com or their parts site, searspartsdirect.com but I suggest you check anyway. You need the model number of your snow blower. Iit will look like 123.123456.
Even if you can't find a parts breakdown I suggest taking the shroud off if you are at all familiar with working on your mower. The shroud on a snowblower just covers the carb like the air cleaner on your mower. If you can use a screwdriver and hand tools, you can do it. Take pictures with your cell phone or draw diagrams showing each piece as you take it off.
Jan 08, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
How can I keep my 2 stage snowblower in high?
I will assume you are referring to the 2 stages in the front of the machine. The spiral auger rakes are the first stage, they are designed to collect the snow and feed it to the impeller. The impeller is the 2nd stage and is to throw the snow up the chute. The lower rakes in the front do nopt throw snow only collect it.
Jan 09, 2010 | Mtd Garden
Huskee Snowblower has to be constantly at high RPM to throw snow
It sounds like the sping that goes from the throttle lever to the govonor arm is either streched or broken.
Jan 20, 2009 | Toro Blowers Rake and Vac - Electric...
Craftsman 4 Cycle Blower/Vac Logo
91 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
