Question about Janome Memory Craft 5700
My needles stuck
My needle is stuck in the plate onthe bottom of my sewing machine can i fix it myself or will i need to bring it to a shop?
    President:
  • 2,976 Answers
If you can get it out of the plate, you will still have to remove the crater it made to eliminate snags. If you have the tools to do that, go for it, otherwise I'd take it to a shop.
Posted on Feb 06, 2009
I have a singer 247 I broke the needle and have replaced it . Now the bobbin will not turn I have taken it apart and still doesn't work if you could help me fix it I would appreciate it
Most likely the needle was broken when a piece of cloth was under the machine right , this means that the needle was slightly bent while it went down to pick up the lower thread , in most of these cases it damaged something fornm the bottom spool.....better check carefullyfor marks and VERY genrly with a new needle in place utrn by hand and see feel where it gets stuck...then replace part or bring to shop to fix ...
Nov 11, 2014 | Sewing Machines
Needle keeps falling out of Pfaff Creativ 2170
change ur needle bar and also check needle size before insert in it.
Sep 14, 2008 | PfaFF Sewing Machines
Frequently, while I am sewing, the needle hits something below the guide plate and gets stuck. I have to remove the guide plate and then the needle will release. What is the problem with my machine?
If the needle gets stuck with no thread, The needle is hitting something. Could be needle not up all the way or something needs adjusting. If it gets stuck with thread. It is probably an upper thread tension or threading issue.
Apr 05, 2014 | Juki DDL-8300
Omega Serger 303 SI thread keeps breaking. How to fix it.
Make sure both needles are new and THE SAME SIZE. Look if there are any needle punctures onthe needle plate and stich fingers.
Machine Tech
Oct 22, 2013 | Sewing Machines
Line needle plate
try a new needle first, then if the needle doesn't line up with the needle plate, then the machine needs a ajustment or has a timing problem and needs to be checked at a sewing machine shop
Oct 01, 2013 | Singer 4423 Sewing Machine
Needle stuck
the machine is out of time & will have to be retimed at a sewing machine shop
Mar 20, 2012 | Singer Sewing Machines
Singer Athena 2009 needle hitting plastic in bobbin case
here's something to check
is the needle inserted all the way in to the needle holder?
needle--flat side goes to the back of the machine
is the needle clamp screw tight or loose?
if the needle is correctly in the needle holder & the needle clamp screw is tight --then the needle bar is out of time & need to be serviced
IF YOU DO HAVE TO TAKE IT TO BE SERVICED AFTER YOU GET IT HOME STOP RIGHT THEN & SEW ON THE MACHINE TO MAKE SURE THEY FIXED THE MACHINE & IT SEWS LIKE IT SUPPOSE TO, I HAD ONE CUSTOMER THAT TOOK THEIR MACHINE TO A SHOP & THEY CLEANED IT AGAIN & DIDN'T FIX IT BUT CHARGED THEM FOR IT & THEY BROUGHT IT TO ME TO FIX & IT HAD TO BE RETIME
did you get a instruction manual for the machine if not check at singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number---2009
Click search--if you don't see a manual--contact singer customer service
Feb 11, 2012 | Singer Sewing Machines
Have PE150 and all of a sudden the needle broke.. so I changed it and now it will not stitch top or bottom. It is like the top and bottom threads are not connecting. a embroidery novice so i'm pretty...
It could be one of two things. Either part of the needle broke off and is jammed under the throat plate or now the timing is off. If you have gotten both pieces of the needle out and know it's not the needle that's causing a problem, then it's the timing. When the needle is about 2mm up from the bottom dead center, the point of the hook on the bobbin case should be center to the needle and just above the eye. You will need to have an authorized repairman fix this since you need a metric tool to fix it. Sorry it's not good news...unless that needle is just stuck in there. thanks for contacting me here on FixYa.
Oct 24, 2009 | Brother PE-150V Computerized Sewing...
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
127 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
