Question about Frigidaire GLWS1233A Top Load Washer
I replaced my splash sheild
And it still splashes out the top when ido full loads
  • 99 Answers
This is joyce
I would suggest to stop doing full loads or to keep top closed on washer while doing clothes. you have a very strong agitator.
Posted on Feb 06, 2009
Replace splash guard FAV6800AWW
Disconnect power supply to the washer then insert a plastic putty knife or similar tool in line with the lid seam, as shown, and push in to release the catches on the left and right side.
Once the catches are released, lift the front of the top cover and tilt toward the rear of the washer. Unsnap the splash guard starting in the lower right corner, as shown, then work around the perimeter until the guard is totally free.
Follow the removal steps in reverse order when installing the new splash guard.
Jun 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Replace a horn on a 2003 dodge caravan
Aug 31, 2009 | 2003 Dodge Caravan
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Legacy Series Top Load Washer
At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
gm shows a recall on the turn siganls / So if you really want to get to the turn signal you either take the bottom of the splash sheild and the fender sheild depending on side go under and replace bulb now according to gm its an issue with condensation so if you need any further info go to my its worth it
Mar 10, 2009 | 2004 Saturn ION
Over flow reserve in 98 intrigue
is this a washer or coolant reservoir/If it is a washer you can take out the splash sheild lower sheild on the bumper and then you can replace it / Please rate my resp[onse thank you very much
Dec 23, 2008 | 1998 Oldsmobile Intrigue
Location of the crank position sensor >
Always by the crank shaft. Probally have to remove a splash sheild on this vehical to see it if you cant reach it from the top.It will be on the right side by the belt pulley
Jul 17, 2008 | 1992 Buick Riviera
Most top loaders are not water tight. They are splash resistant. I'm guessing that your water level is too high or you are loading your clothing into a machine that is already full of water raising the water level excessively.
If you allow your machine to fill with no clothes for test purposes, you should see a level about 3 inches below the top of the agitator. If it is higher than that, I suggest that you investigate why or use a lower water setting.
Jun 16, 2008 | Washing Machines
1996 saturn waterpump
If you take off the tire and splash sheild you can get to from there. You have to move the a/c off to the side to get to easy from the top. Loosen the bolts before taking the belt off.
May 14, 2008 | 1996 Saturn SC
Water splash sheild ineffective
My machine may be a different model, but seems to have similar problems. I resolved this by: a) making sure the splash shield is fastened correctly at all points round the tub (it worked loose) b) as a temporary fix reversed the foam gasket inside the splashshield until I get a new one
Aug 22, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
73 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
