Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Where to clean coils
I have a 14 upright self defrosting. Can't figure out how to clean the coils??
  • 410 Answers
This freezer has what is called a hot wall condenser so there are no coils for you to clean. make sure that you dont put anything right on top or real close to the sides of the unit and you will be ok. thx for using fixya peyton
Posted on Feb 06, 2009
How does the Ignis afe550/ig Upright Freezer defrost?
I couldn't find any info on your freezer but there are 2 main ways units defrost. The first is manual defrost where you have to unplug the unit to defrost it yourself. These unit are typically chest freezers and upright freezers that have no fan and the refrigerant runs through the shelves. You can tell because frost will mainly build up on the shelves themselves. The second is self defrost. These units will have a fan in the freezer and a evaporator coil behind a wall inside the freezer. This wall is usually inside the freezer on the back wall. These units have a heater that is activated by a timer and comes on every 8 hours or so and will heat the coil for 20 to 30 minutes. This removes all the frost build up on the coil and you should never have to do anything. I hope this helps.
Feb 22, 2015 | Freezers
My GE upright frost free freezer is not cold enough to freeze food anymore.....its cold but not freezer cold....stuff is defrosting....what could be wrong. I hear it running, but I dont hear it go off...
without getting all technical, look for the condenser coil and be sure it is clean. Some are under the refrigerator and can be accessed by removing a "kick plate." Some are under and in the back and can be accessed by removing a cover with a few screws. Some units have a small fan that moves air over the condenser coil. Look for it and see if it is running. And then there are some that have coils that run up the rear of the unit and when it is pushed back against the wall, the air can not circulate and can cause this issue. This is the simple first step to do before getting a service tech involved.
Dec 16, 2017 | GE 20.3 cu. ft. / 575 liter Upright...
There is a red glow from coil at bottom back of freezer that I can see through slats from inside. There is a sizzling water drip happening.
there is an element in there for self-defrosting, if you have a self-defrosting model. It heats up like an oven element ( not nearly as hot) to get rid of frost build up.
Nov 09, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
I lost my owners manual. How do I defrost my upright freezer
they can be defrosted by using a blow dryer on the evaporator coil.or most common way is to remove all the product in the freezer and turn the unit off and leave the door open. most units have a defrost heater and they self defrost but if you are building up frost then you may need to check the continuity on the heating element and replace if need to. or check and make sure the defrost timer is working properly
Oct 09, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Maytag upright freezer with self defrost. The water line freezes.
This sounds like your defrost heating coil has gon bad. Not much you can do but replace it. Please leave a good thumbs up for me for the effort. Pretty sure I'm correct on this one. The Raz Shack
Mar 11, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
I have an Maytag upright freezer.Does it self defrost?if so how does it self defrost?Do you have to leave the plug and hose out all the time? model # is rfu1500aaw
This is not a self defrosting freezer . Remove the plug and hose ONLY when you unplug to defrost . You should defrost when the coils get about 1/4 " of frost (ice) on them . Otherwise , the frost will act like the plastic insulation on electrical wire , not letting the coldness freeze the food solidly .
Sep 04, 2009 | Maytag Freezers
Not cooling it is on and has been working fine, but woke up today and everything is melting- being thawed out - freezer is not cold
You need to check Condenser -
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Good Luck!!
Thanks
Jul 19, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Freezer wont freeze, compressor always running, refrigerator not cold
HI,
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Jul 03, 2009 | Traulsen Freezer Refrigeration 4 - 1/2...
In addition to the popping noise/coils are froze with orignal
turns out the coils were not defrosting or at best working intermittently. I defrosted the coils and ordered a defrost timer the old timer continued to pop from intermittently.I replaced the defrost timer
and it quit popping and noew the freezer works fine temps range between 9 degrees F and
14 degrees f.
Jan 19, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer
You should check the drain hose inside underneath the freezer.This is done at the back down below. Mine was looped too high and water could not get out. I took the loop off that was holding the hose and now water can drain away without freezing. You can pour warm water down the drain hole to melt the ice in the tube if you remove the grate covering it inside the freezer. I have read that several Kenmore upright freezer
owners have the same problem. I was astonished that this was the problem and I had put up with it for too long, defrosting the freezer every 2-3 months!.Give it a try!
Nov 27, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
349 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
