Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch 2060 Door Won't Close
We have a Bosch 2060 washer and now the front door will not close/latch. I have tried to hold it closed and press the start button. This does not work but sometimes it causes the two bottom lights to blink.
Certainly would appreciate any ideas.
  • dave486 Feb 10, 2009
    Thanks for pointing me in the right direction. A small piece that appears to be part of the inner door ring has broken apart. This in turn made it impossible for the door latch to function properly.
    I have been able to create a temporary fix with homemade parts but don't know how long it will last.
    Would you know where I could purchase the spare parts (inner door ring and latch)?
    Thanks again,
    Dave
  • dave486 Feb 11, 2009
    Thanks Joyce,
    I am in Luxembourg but have a military APO shipping address, so items can be shipped via USPS.
    Cheers,
    Dave
    Scholar:
  • 99 Answers
This is joyce
Replace door latch
thanks
joyce
Posted on Feb 07, 2009
  • JOYCE BROOKS Feb 10, 2009
    This is joyce
    Where are you at and I will look it up!
  • JOYCE BROOKS Feb 13, 2009
    This is joyce
    Go to bosch.com and order part for your model # on line. and have shipped to you.
    thanks
    joyce
Washer won't start
Sounds like the door lock may be faulty or it isn't closed fully. If it has a child lock check you haven't set it by mistake, you have to hold the start for 5 secs+ to override it.
Mar 07, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
When I start my Bosch Axxis machine - I purchased it used - I do not hear the water start and the cycle isn't starting.
When you close door properly and press start does the door latch? If not possibly the latch is the problem. If it doesnt give a normally closed condition, the micro processor wont continue.
Sep 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch dishwasher won't latch
No you did good in ordering a latch ,that is a common issue i find with the bosch d/w, for no apparent reason the latch locks itself with the door open. Look at the door where the male part of the latch goes into the door, you will see that is locked. if you take it apart and manually unlock the latch u stand to break it. Again you did good on ordering the latch.
Jan 09, 2009 | Bosch 36 Inch Pyramid Chimney Hood - Black
Door Open, Door Latch Locked
yes that loop is the release.
if you pull push it and its stiff , spray some wd 40 in the unit .
its likely binding against the plastics.
so just spray away and wait a few mins.
many folks says lubing it is a fix.
May 03, 2008 | Bosch WFMC 3200 Front Load Washer
Can't close Bosch Dishwasher door
I had same problem and was alarmed at the idea of taking the door apart, so I tried the 2 screwdriver option described below - it works!
Open door and get two small screwdirvers behind each side of the catch inside the top of the door and gently apply pressure. The catch should reset itself on 'open' and allow you to shut the door again.
Thanks to all for their postings and helpful advice!
Nov 10, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Won't turn on
My Bosch washer turns on when I turn the temperature selection dial. I assume you have tried this and waited for a few moments for the washer to gather itself and start.
May 17, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
310 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
