Question about Philips Televison & Video
Philips rear projection t.v
The problem is the tv is doubled picture and the colors are all messed up.the model is 46pp930217 and there is another # dptv330
  • 2 more comments
  • bobbiflower Feb 07, 2009
    Has anyone else had this problem and if so did it fix it or not. And do you get the whole board when you order
  • bobbiflower Feb 08, 2009
    My husband got the board out and says there is a difference.There is a extra silver box on the board that ours does not have.From your picture it is front and center Our t.v has a has a # dptv303 the kits # are dptv305 to dptv345 does this matter.
  • bobbiflower May 12, 2009
    Just wanted everyone to know this fixed the problem thanks
  • bobbiflower May 21, 2009
    Slinteriors ok do not know how to get a hold of you.I purchased the premium package.To get an answer on our hdtv philips 55pp9753/17.We did what they said, changed the stk's and resistors. But now the tv will not hold the converge. Are there other resistors that control the converge and would this be the solution?
  • Philips Master
  • 8,617 Answers
The convergence ICs and resistors need replacemnet. You can get the DOTV305-DPTV345 convergence repair kit at the following link which includes both ICs and all the feed resistors plus step by step instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Feb 06, 2009
  • Sonny Berry
    Sonny Berry Feb 07, 2009
    No the kit has the components to fix the convergence circuit on the board, that board cost almost 500.00 read the coments on that repair kit for your model its an easy fix.
  • Sonny Berry
    Sonny Berry Feb 08, 2009
    Actually thst kit will work for all phippips Tvs from the early PTV800 chassis all the way up to the DPTV500 series TV.
COLOR IS NOT RIGHT double outline
if its a Philips as indicated here that model has no reset--if picture looks 3d etc for model listed here it is a convergence problem.
Apr 08, 2012 | Philips 60PP9202 60" Rear Projection...
Red will not line up on a philips mod 46pp930217 and i can't get the color to ajust
Your convergence chips have failed and need to be replaced. You can get the parts and instructions from www.TvRepairKits.com
Apr 30, 2009 | Philips 46PP9302 46" Rear Projection...
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
60" rca tv has a double picture
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
Apr 05, 2009 | RCA D61130 61" Rear Projection Television
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
DOUBLE PICTURE WITH DIFFERENT COLOR
this is a convergence problem,
well worth fixing
I would have a TV repairman take a look at it.
Regards,
daniel.
Jan 12, 2009 | Philips Magnavox 51MP392H Rear Projection...
TV Color
You need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt metal film resistors. You can get the ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
Jul 04, 2008 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
251 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
