Question about Ruud Central System Air Conditioner
Is there a connection between a warm floor and a water heater?
Our water heater is raised in the corner of our garage. The room on the other side of the wall with the water heater has a warm floor. Is this normal?
  • Jim London
    Jim London May 11, 2010
    Hi, Do the pipes run under or over, what type of foundation do you have ? is it a concrete slab, wood joists ect. we need more info please.
  • 56 Answers
Is the floor warm just in certain spots or all over. If just in a certain spot you may have a hot water line leaking in floor.
Posted on Feb 12, 2009
Just bought it and want to know how to fill it with water
gee think you need to hook the water lines up on the back of it
Jun 16, 2015 | Washing Machines
Can a sterling garage heater be vented out a side wall of a garage
Yes, should have a chart in the installation book that shows distances to windows.
Sep 23, 2014 | Sterling RF30 Natural Gas Garage Heater
What size fresh air vent do I need in a boiler room with a gas boiler and gas hot water heater with about 220,000 btu combined
I suggest that you run a duct that is 3 inches larger than the furnace duct . and you should run it down close to the floor and aim it in the direction of the furnace. this will trap warm air above the vent and supply an adequate supply of air for combustion. also make sure you have insulated any pipes in the furnace room that carry water or steam you want heat where you live, not going up the chimney.
Aug 02, 2014 | Water Heaters
Where is the defroster
Defrost on most units works like this. An electric wire heater is embedded in the cooling coil where the air is cooled. A timer periodically shuts off the refrigerator and turns on this electric heater coil which melts the frost off the coil. The water from this defrost collect s in a trough below the coil and drains down thru tubes into a shallow plastic tray under the unit. The water does not collect there but is evaporated over time by the hot air that blows over top of the water by the fan that comes back on when the refrigerator returns to cooling cycle. This is the fan that sucks air from the room over the condenser coil under the fridge to make the refrigeration work. The air is warm after passing over the condenser coil and then the air passes over the water tray. You can feel the warm air returning back into the room if you out your hand down near the floor.
Mar 16, 2014 | GE GSS20IEP Side by Side Refrigerator
Underfloor heating not working
Along with warming up the entire area, people also look to warm up the floor, which can otherwise be harshly cold. Underfloor heating sdystem is the most consistent form as it evenly warms up the complete open space. Infrared Heater Room Heater IR Heater Magneto
Jan 26, 2014 | Heating & Cooling
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
Fluval m200 heater is lit and warm but still hasnt heated tank after 36 hrs..200 ltr tank is this normal
Hello. You haven't stated the room temperature and what temp you are trying to raise your tank to, but it sure sounds like the tank is too large for the heater wattage you chose for the tank. The basic rule of thumb is 3-5 watts per gal (about .75 to 1.5 W per ltr) to raise the tank 5 deg-F (approx 2.5 deg-C) above room temp. If you need to raise the tank temp even more, then you will have to choose a larger heater. Using the rule of thumb I would choose at least a 300W heater for a 200ltr tank. Also, do not forget to include the capacity of your refugium/sump, if you use one, in the calculation of your water quantity because you are heating that mass of water as well as your tank.
Jan 26, 2010 | Kitchen Appliances - Others
It's leaking slowly from the top It's a Rheem 82v52-2 water heater and we came home and there was a puddle of water in the floor. It's a slow and steady leak. It starts at the top on the right side. I...
if the line feels cold its the fill line if warm its the hot line either line try to tighten the connection if no good or leak is from solder or connection if u have valves to and out shut them off or turn off main open a faucet relieve pressure at heater either solder the line to repair or if connection Teflon tape joint and retighten connection good luck and thanks for using fixya
Oct 10, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water on Drivers side Saturn SC2
Is it antifreeeze from heater core or heater core hose leak?  Is the leak pure water, or maybe something else?
Put it in the garage again overnight with an old white towel in the drivers foot well, best if you can find a way to stretch it from drivers seat forwar to firewall and keep it off of floor mat.  Check it before you go to bed,  then in the morning if no leak found yet.  see if the color/location of the spot helps you identify the source.  I think the heater core is under the dash center.  Anti freeze is green/yellow or orange.
good luck
Nov 06, 2008 | 2004 Saturn L-Series
Ruud Central System Air Conditioner Logo
70 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
