Question about LG Vu CU920 Cellular Phone
Phone Book to Bluetooth Display
I cannot get my contact list to connect to my BMW X-5 bluetooth display. I am able to answer and end calls; however, I have to manually enter a telephone number via my handset.  The AT&T store technician spent over an hour attempting to get my problem resolved but to no avail.  The BMW dealership tells me it's probably a software problem.
I did not have this problem with my old Motorola Razor.
Help!
  • fishes61 Mar 08, 2009
    I also have this problem... I recently upgraded to the LG VU phone, and I was able to pair it up with my 2008 BMW 328i... my contact list will not download and I have to manually dial the numbers and end the calls. Does anyone know if or how this can be fixed?
  • 208 Answers
Go to www.wireless4bmw.com for the latest list of phones that are compatible. Not all phones are compatible with each model. You can search by your car and it will provide a list of the phones from each carrier tested compatible.
Posted on Mar 12, 2009
Bluetooth pairing. Audio works but contacts not transferred to car. Samsung Galaxy S3 says "audio only"
Having same problem. Same galaxy 3 Phone not compatible with my
BMW system bluetooth either.
May 04, 2014 | 2006 BMW 5 Series
Where is sync?
Pairing a Nokia Lumia 520 to a 2013 Ford Escape
1. To Find "Bluetooth" on the Nokia Lumia 520
  • Slide your finger left on the display.
  • Press Settings.
  • Press Bluetooth.
2. Turn on Bluetooth
  • Press the indicator next to "Status" to turn on Bluetooth.
3. Pair a Bluetooth device with your phone
  • Make sure the vehicle (parked in a driveway) is turned on and engine running. Go tot he Phone Menu, System Settings, Add Bluetooth Device, Push OK, The Sync System will display a 6-digit PIN number. Use the Seek Arrows to change to Special PIN (the system will display 0000), Push OK.
  • Your phone now searches for devices and after a moment, a list of Bluetooth devices within range is displayed.
  • Press the required Bluetooth device (the tab should say Sync).
  • Follow the instructions on the display to pair the Bluetooth device with your phone. Enter the 4-digit PIN
  • The new device is displayed on the list of paired devices.
  • Press OK on the console screen to set as Primary Phone, set 911 Assist and Download Phonebook. Be sure to check your phone screen and check "Always Connect" and Yes to approve the phonebook download. Be sure to check to see is there is also a request to Always Connect for SMS (texting) alerts.
4. Return to the home screen
  • Press the Home key to return to the home screen.
Your phone should now be paired the Sync system. Use the Voice button on the steering wheel to start the process (say "Phone"). Use the Phone icon to answer (a quick push) or hang up (push and hold down for about five seconds).
For more info www.fordtechlane.com Ford Tech Lane Driving you on the fastlane of vehicle technology
Mar 05, 2014 | Nokia Lumia 520 Smartphone - Wireless LAN...
Will not connect to my sonyericsson w995
i checked that your phone is compatible wd the parrot handsfree bluetooth.
turn-on your bluetooth of your phone
turn on bluetooth of your parrot handsfree see manual where the buton is located
From the phone:
* Go to MENU / SETTINGS / CONNECTIVITY / BLUETOOTH / MY DEVICES / NEW DEVICE
* Phone will search for available bluetooth devices
* Select Parrot Product from the list
* Enter Passcode "1234" and go to OK
* Accept the pop-up
* Devices are now paired and connected
fleche.gifSending contacts via Bluetooth
Jan 29, 2011 | Parrot Hands-Free Car Kit with LCD Display...
When i connect my veiwty to my parrott i can make calls if i use the phone but if i go to phonebook on the parrott it wont bring my contacts list up can any one help
change the parrots phone book settings to use the parotts phone book. you will have to wait 5 minutes for the phone book to load then program your voice commands.
Apr 04, 2010 | Parrot Hands-Free Car Kit with LCD Display...
Parrot CK3100 won't import Contact list from Nokia 6210 Navigator
Try this.
* To send several contacts at once:
* On the phone go to MENU / CONTACTS
* Select a contact to send by pressing OPTIONS / MARK-UNMARK / MARK
* Select your contacts to send then select OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / MORE DEVICES
* The phone will search for available devices
* Select the CK3100 from the list and the contacts are sent to your car kit
Nov 13, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Ford blue tooth connection with my LG viewty phone
Car should be under warranty. First stop is to the dealership. Sounds like sync software issue. You may need to wait until an update is available. Good luck.
Sep 11, 2008 | 2008 Ford Focus SE Sedan
I can set up my headset to my new phone
Step 1 - Enable Bluetooth functionality on the Motorola V3m. Note: The Bluetooth power must be set to ON position to pair the device. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Setup, press [Center NavKey]. Scroll to Power XXX, press [Center NavKey]. Scroll to On or OFF, press [Center NavKey]. Step 2 - Put your fully charged Bluetooth headset into pairing mode. Start with your Bluetooth accessory powered off. Hold down the power/end key for 5 seconds. You'll hear a short beep and the LED light turns red. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset. Step 3 - Pair the Motorola V3m with a Bluetooth Accessory. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Handsfree, press [Center NavKey]. Place accessory in pairing mode. See accessory pairing instructions. Scroll to Look For Devices, press [Center NavKey]. Phone displays Scanning. Scroll to XXXAccessory NameXXX, press [Center NavKey]. Phone displays Bond With XXXAccessory NameXXX. Press Yes [Right SoftKey]. Phone displays Enter Passkey. Enter 0000, press [Center NavKey]. (See accessory instructions as passcode may vary.) Phone displays Connected.
Jun 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG Vu CU920 Cellular Phone Logo
134 people viewed this question
Top LG Cell Phones Experts
IT Solution
IT Solution
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
