Question about GE Monogram ZDI15C Automatic Icemaker
Water freezes on slab & Builds Up will not fall on Wires
The water flow over the slab and it keeps freezing and builds up to 2 Inch block of ice on slab.and wont slide off onto the wires
  • 3 Answers
We had this problem. You need to clean the freezing try using a green scouring pad and the solution they recommend in the user manual. You need to scrub the tray with forward backward motions until slippery clean. All surfaces need to be clean and free of plack. it will work like new if you do this. Need to remove the cutting try first.
Posted on Aug 22, 2009
Kenmore freezer freezes up
By the movie you have an upright freezer. The worst type any body can own. Every time you open the door cold air flows out onto the floor and is replaced by room temp air that is heavy in humidity (water vapour). This freezes into ice and the more you open the door the more ice you will get. Also if the door gaskets(seals) are not perfect you will get the same result.
May 05, 2013 | Freezers
Water in bottom freezer
Sounds like possible defrost drain. Water builds up over time. Need to pull evap cover and see if ice is build up in tray. If so defrost drain, should fix issue
Aug 24, 2012 | Maytag MBF2258XEW
Ice maker is splashing water all over back of freezer and it builds up til the fan starts to make noise if I turn it off and defrost the ice it will start up noise free til the ice builds again.
What is the model number of your unit? When the ice builds up, does the ice just build up where it is splashing or is the ice also building up behind the back wall of the freezer?
Thank you! Richard
Jul 21, 2011 | Refrigerators
On my VISB542SS the ice maker , water leaks into the drawer when ice is being made, Ihave removed the unit to check for leaks bot find none.
The ice tray releases the ice because the mechanism twists the tray during the end of the cycle. Sediment builds up in the ice try over time and the smooth Teflon surface is no longer smooth, and the ice can get a "grip" on the tray. Then when the tray is twisted, a few cubes remain in the tray. When the measured amount of water then flows into the tray on the next cycle, it is too much. It freezes over the top of the tray, and the next time the tray is twisted, no ice falls out. When water is injected after this, it just runs off the top of the tray into the bin, freezing the ice in the bin. Replace the ice tray every 3-4 years with a new ice tray, and the problem disappears.
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting
Oct 15, 2010 | Viking Refrigerators
I Ice maker keeps freezing and it builds up so
Either your water flow is too strong, your fill tube has dislodged from your Ice Maker, or your water valve is clogged with lime and defective.
I would opt for the obvious culprit, the fill valve. These are easy to replace and not expensive. First turn off the water to your refrigerator. Pull your fridge from the wall and follow the opaque tube at the top of your fridge down to the little aqua blue device with 2 wires connected to it. Note that fridges with cold water and ice have a dual valve with 4 wires but look similar. There will be 1 or 2 screws holding that in. Remove that valve and record the model number. Call either or 1stsource parts for replacement, or find a local dealer who has good prices. Replace the hoses in the order you removed them and you should be fine.
Mar 13, 2010 | Maytag MZD2766GES Side by Side...
GE side by side leaks water onto floor, no ice
There is a pipe that runs up the back of the appliance and feeds the ice maker , if this freezes inside then it canpush the fitting off the back of the appliance and cause water to go everywhere. Usual problem is a leaky watervalve causeing water to drip into the pipe which freezes and builds up until it is totally blocked.
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Monogram ZDI15C Automatic Icemaker Logo
142 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
