Question about Whirlpool Duet GHW9150P Front Load Washer
My washer shows the display but when I push the start button it s
Shuts down
  • 6,784 Answers
Your power supply board has failed. it will have to be replaced. thanks for using fixya:)
Posted on Feb 06, 2009
  • Michael Masters
    Michael Masters Feb 06, 2009
    if not the power then, it must be the main that has failed.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, your described problem almost always indicate a cold solder in the 5 VDC supply of the controller module. While this is repairable by re-application heat on the solder joint with a soldering iron. In some instances, this could also be a leaky/faulty capacitor again in the 5VDC/power supply section.
Pls post back if you are considering a DIY (do-it-yourself). Requirements would be familiarity with electronic components & circuitry, a soldering iron and preferably a DVM/VOM. You can also try looking for a tech sheet at the bottom/kick panel which include a wiring diagram.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 06, 2009
    Have you checked for the techsheet?
    Sergeant:
  • 326 Answers
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
  • moniter Feb 06, 2009
    check for 110v at p7 pin 2 to nuetual p5 of the machine control board when calling for cold water, if its missing replace the board if present is wiring to the valve.or may be you will have to replace the whole control board if major fault on the board.
My washing machine shows UE errors
The UE Error Code indicates that the laundry load is unbalanced. Just redistribute the load and when you shut the lid it should start to re-spin again. On some machine you have to push the start button.
Apr 09, 2014 | Samsung SW62ASP Top Load Washer
When I turn my Samsung VRT front loader on, the hourglass will not go off and washer start.
I am having the same issue as well i.e i can set the cycle but the washer wont start (the hourglass Icon remains lit). If i press the off button. The display shows off but the display doesnt shut down. Thought this might a control board issue. Bought one off of ebay & replaced it. Did not make any difference (p.s the machine is outside of US so calling service is not an option).
Jun 19, 2012 | Samsung WF330ANW 4.3 Cu. Ft. Front Load...
Washer showing test
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work
Hope this helps
Jan 01, 2012 | Hotpoint Washing Machines
HE2 Plus Washer starts then shuts off immediately.
Aren't microprocessor controlled appliances wonderful? Especially when the code is flawed! No wonder the space program bit the dust!
May 12, 2017 | Kenmore HE2 Plus Front Load Washer
Have a kenmore front load washer and shows pau 45 in the display. Whatever button i press shows err cannot do anything with the machine.
LOC means it thinks the control panel is locked.
This gives the ERR indication when you push the buttons.
To unlock it you need to hold down the Options and Select buttons together until it reacts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2010 | Kenmore 46462 Front Load Washer
Shuts down when start button is pushed
There is likely a short on the ECU and it must be replaced. Further testing should be conducted by a professional in this case.
Aug 08, 2009 | Kenmore HE3T Washer
Whirlpool front loading washer
I am having trouble starting the washer . I set the cycle on casual and press the start button and the washer sensor showed to " Done" instead of starting. I only bought it three months ago.
Jul 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Pushing Start Button only results in "Beep, beep, beep"
Need to check that the lid is shut properly and the door is locking. You don't mention an error code in the display. Make sure there isn't one showing.
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer won't start
First of all, does the washer make a distinctive "click" when you push the START button? This is an indication that your door latch is locking (or at least making an attempt to lock). Normally, however, the display would have an "fdl" fault code indicating a door lock failure if it were bad. I have seen the latch go bad and not register a fault code, though. You can perform this simple diagnostic test to see if any fault codes register: 1. Select DRAIN/SPIN 2. Under SPIN SPEED select NO SPIN 3. Then, under OPTIONS push the PREWASH button 4 times. You should hear the door latch click then "C00" will show on the display. The washer will begin a series of tests (C01...C05 - depending on options and model) by testing the hot and cold fill valves, the various dispenser compartments, followed by tumble, drain and spin. If there is something wrong the diagnostic test will abort and a fault code will be displayed. The washer usually beeps when it displays a fault code. If you attempt to perform the diagnostic and the display momentarily flashes after you press the PREWASH button the fourth time and goes out, this can also be a symptom of bad door latch. You need to perform these simple steps first in order to further diagnose. Let me know what you come up with.
Jun 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
