Back to:
Tags:
Vornado Air Circulator Fan
House too COLD!
By Melissa - usenet poster
I live in a terribly designed house. It is approx.. 1800sq ft. two story
with a vaulted ceiling and an open loft. It has a single HVAC system, gas
furnace with the thermostat located upstairs. I had the system
checked/serviced when we moved in a little over a year ago.
Using thermometers upstairs and downstairs, I see and feel as much as a 6
degree difference between upstairs and downstairs. When the thermostat is
set for 70 downstairs can be 64 degrees. If I turn the thermostat up to 74
the downstairs is 68. Hot upstairs, barely warm down.
Are their any simple techniques to help? Should I close off all the air
vents upstairs and open the ones down since heat rises? What is the trick
to living in this type of house? ;-)
Thanks for any input.
-Tim
eFax (508) 590-0302
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Peter1
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Ceiling fans ,Ted,ceiling fans, jess like Ingrid sez.. A ceiling fan hanging
from a long pipe can look great in a vaulted room,makes um look even higher.
Something that goes with the decor, ( brass pipe,antiqued,polished?)
multi-speed ,reversable,a little tweaking and you got it destratified. Just
make sure that they are highquality, heavy and completly balanced; hangining
from a long pipe they will really wobble.Vornados etc, always seemed to move
the air too fast,make a breeze,and you gotta hide them. Jeeze Ingrid, I don't
think he was trying to pass the blame, Tri-finned stargazers. Now there's a
poor design.
what it be?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on House too COLD!:
I don't want to Accept this solution
Solution #2
Not Rated (0)
LiZzIe
Rating: 0%, 0 votes
Almost sounds like a domehome... a reversible big ceiling fan will do the
job. Push hot air down in winter, draw cool air up in summer. Ingrid
in the Frozen Tundra zone 5 sorta
List Manager: Puregold Goldfish List
for care of goldfish go to #
Solve the problem, dont waste energy finding who's to blame
Thank You!
Solution #3
Not Rated (0)
Perkins
Rating: 0%, 0 votes
Hi, Tim.
First, I'd check for leaks, throughout the house. The "chimney effect" can
be kicking in, sucking cold air in down below.
Then, I'd try to find heat losses, and address them: inadequate insulation,
"high-e" doors and windows.
Then it makes sense to try to "destratify" things. Moving air from low
point below to high point above. This will be difficult to do with HVAC
air-handling system alone, unless it can draw in air at upper ceiling, or
discharge and diffuse air at upper ceiling level. If you have a clear path
between levels, small air-circulator fans like "Vornado" can quietly
circulate lots of air, like from lower floor to upper ceiling.
Else, you might try such a circulator on each floor to destratify it, and
use any means available to move air in a loop from upper to lower. Like the
HVAC air-mover. (Most systems have fan settings: "On | Auto | Off".
Once leaks and losses are under control, you need surprisingly little air
movement to keep things destratified, in my experience.
Regards,
John
Thank You!
Solution #4
Not Rated (0)
Bomber
Rating: 0%, 0 votes
You should set the upstairs air vents almost closed in the winter (you
need a little ventilation always) and the downstairs air vents almost
closed in the summer. It might make more sense to relocate the
thermostat downstairs, or install two.
Thank You!
Solution #5
Not Rated (0)
Brad
Rating: 0%, 0 votes
Check the humidity in your house. Often it is as low as 10% in the winter. This
will cause it to seem to be a lot colder than it realy is. Before I got a
humidifier 76F felt chilly now we are comfortable at 72F and sometimes less.
Thank You!
Solution #6
Not Rated (0)
paulrmc
Rating: 0%, 0 votes
Get a 2 speed fan for the furnace and leave it running in low speed
constantly only going into high for heat/cool. This will constantly mix the
house air leading to more uniform temperatures.
Slowly close the registers in 'hot' rooms (maybe 1/4 per day) while the
registers in 'cold' rooms are likely already wide open.
Got lots of windows in the cold rooms? Consider window coverings - or my
favorite - clear plastic on the inside.
Is there a door to seperate the 2 floors? If so - close it to prevent the
cold air from falling / hot air from rising.
You could install a ceiling fan in the vaulted ceiling - but I'd try the
above first.
Roger in Winnipeg
Thank You!
Can you Help with these Electric Fans problems?
Electric Fans
I've lost my ceiling fan remote and there is no other way...
Electric Fans
my hunter fan leaks oil and hunter tells me i need to take...
Electric Fans
I have several lamp sets that need rewiring. They are...
Electric Fans
We current own a hunter fan with remote 85094, that seems...
Electric Fans
All I've found are dimmers that require 4 LR6 fixtures to...
Loading problems.
Repair Service
Find Electric Fan Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
