Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
The phone reads Line In Use and I cannot make outgoing calls.
There is no dial tone but it is not the outside wiring, I already checked.
Something must have been pressed on the one of the phones. I have 3 bases.
I have the same problem... God forbid you need to use it for an emergency! We have found that my neighbor has the same problem when you pick up the phone it sounds like an ECHO CHAMBER...we have purchased the (4) Pack set w/digital answering machine built in the base.
SOLUTION which we found to work is to unplug the power and the phone cord from the base for approx. (1) one minute, then reconnect the same.. It will take approx. up to a minute to recycle again and go back into the normal mode. Good luck... Mine is a peice of S*!T...UNIDEN should be asshamed of themselfs on this one... NOT WORTH $150 which I spent on it.. But I would by it at $2 (TWO) dollars and use it as a paper weight.
Posted on Feb 11, 2009
  • Gerry Russ Feb 15, 2009
    Our Solution :
    Thank you for using our system.
    (Unfortunately it seems that your product is defective. Please read the procedures outlined below for your service options.)
    To better serve you, our customers, Uniden Service Inc. does not repair cordless telephones or two-way radios. Rather than be serviced by a Uniden technician these products will either be replaced under the Uniden Replacement Program (In Warranty Customers) or offered a discounted replacement under the Uniden Loyalty Program (Out of Warranty Customers).
    Warranty Service
    In order to have your unit handled under "Warranty" you must provide the following items:
    Your name, phone number, and shipping address.
    The serial number and model number of the unit that needs warranty service.
    A copy of the receipt you received when you purchased the unit that needs warranty service.
    A credit card, money order, or check to pay for shipping and handling of the replacement unit.
    **If you do not have a copy of the receipt then we can not verify you as the original retail owner and can not verify the unit as being purchased "new". Therefore your unit will be handled via the "Out of Warranty" service procedure.**
    Out of Warranty Service
    In order to have your unit handled "Out of Warranty" you must provide the following items:
    A credit card to pay for shipping & handling and the cost of the replacement unit.
    Replacement Program
    The replacement program is designed to better serve Uniden customers by making it simple to start their service repair order and to get their issue resolved quickly. This program is used to handle IN WARRANTY customers by replacing your cordless telephone, accessory handset, or two-way radio without requiring you to send the product to a repair facility. When determining a suitable replacement the program takes into consideration the technology and features of the original model that is in need of warranty service. If the same model is available then it will be used to replace your unit, if the same model is not available then a comparable unit will be used to replace your unit. Your order will be processed when we receive a copy of your receipt either via fax or mail.
CS6482 model phone system; (1) base unit, (1) additional phone. Cordless phones are both showing "LIne In Use" but there is no dial tone and neither phone is "in use"
The "Line in Use" message often occurs when there is no dial tone. You'll need to identify where the dial tone problem is coming from. First, check that the base has power and try a new RJ-11 cable between the jack and the base. I like to use a old corded handset phone for additional testing. First plug in a different phone to the jack. Do you have a dial tone? If you do, then the CS6482 has failed.
If there is no dial tone, next try plugging the test phone into a different phone jack, if one is available. If there is a dial tone at another jack and a new cord didn't help at the first jack, then you have a wiring fault at the first jack. This could be in the jack itself or in the wiring to where the phone service comes in. You can fix the jack more easily. Remove the cover plate and determine the type of jack and look for a loose wire. If the wires are attached to screws, you remove the insulation from the end of the conductor and slide it under the appropriate screw. Then tighten the screw onto the wire. For keystone jacks, you'll need a push-down tool to press the wire back into place. The tool is sold in most hardware stores in the electrical aisle. Do not strip the wire before pushing it into place. See http://cablesupply.com/content/47-telephone-connections-and-rj11 to match the wire colors to the correct pin on the jack.
If you do not have a dial tone at another jack or do not have another phone jack in the house to test, find the service box. Open the box and check the connection type. If you find an RJ-11 jack, use your test phone to check for a dial tone. If there is no dial tone or it isn't an RJ-11 jack, contact your telephone company. They can test the phone line and will repair the wires for free if there is outside damage. If the problem is inside the walls, the telephone company will charge a fee to repair the issue. (This may be easier than finding a broken wire in the wall yourself.) Note: some telephone companies are trying to move residential units to newer fiber optic services and do not want to repair the copper wire to the door. This can cause problems with some security phone alerts.
I know at least twice we lost the dial tone on copper wiring after rodents chewed on the wires. That issue hasn't repeated since we were upgraded to fiber. However, during the upgrade, the installer dropped one of the RJ-11 lines behind the siding on the outside wall. Thus one phone was without a dial tone, we found the dangling wire and restored the phone service in seconds. We also lost the dial tone after contractors dug into the underground telephone service up the road from us. That was repaired quickly.
I hope this helps.
Aug 16, 2016 | Lands Phones
My phone says "Line in use" but nobody is using it.
Some of my telephones will read "Line In Use" when the phone doesn't detect a dial tone. I like to use an old wired telephone to check whether the problem is with the cordless phone base or the phone line wiring.
First plug in the test phone and check for a dial tone. If there is no dial tone, try a different RJ-11 cable between the phone and the jack. If there is still no dial tone, use the test phone at another jack and check for a dial tone. If you have two jacks with no dial tone, find your incoming telephone service box. If you have a relatively new phone service installation, the service box will have RJ-11 jacks. Plug your test phone into the jack and check for a dial tone. If there is still no dial tone, contact your telephone company. They will repair an outside wiring problem for free. If the service box doesn't have an RJ-11 jack, you'll need to ask your telephone company to test the phone line for you.
If there is a dial tone at another jack or at the service box, you have an inside wiring problem. You can check for loose or broken wires inside of the jack. Most use either screw terminals or a punch-down design. For the screw terminals, strip another section of the unbroken part of the wire, if needed. Secure the wire under the screw. For the punch-down terminal, take off the cover. Then you'll need a tool that is available in most hardware stores in the electrical wiring section. Do not strip the wire; just place it over the correct place in the terminal and push it into the contacts with the tool. Trim off any excess wire with a small pair of small wire cutting pliers, if the excess wire is blocking the cover from fitting back onto the terminal. http://www.lanshack.com/wire_phone_jack.aspx has a good diagram of the wire color and pin assignments. If the wiring is okay at the jack, you'll need to check the rest of the wiring for problems. Since the broken wire might be inside the wall, you may want to have a professional check it out. Your telephone provider's technicians can do this for a fee. If you have a DSL computer line, you should check the DSL filter. If the filter is inside at the jack, you'll need to replace the filter. If it is out at the service box, your telephone company will do the replacement.
If there is a dial tone at the jack with the test phone, check the purchase date on the L401 system. If it is under warranty (1 year usually), contact Motorola. Otherwise, replace your Motorola phone system. It's generally not worth the minimum repair and shipping costs.
I hope this helps.
(I've had dial tone issues after lightning strikes (the DSL filter was damaged), mice eating wires (buried phone line) and due to county road crew/contractors who dug too close to the wire. The first two problems required phone calls to get a technician to fix the outside line. The last one gets fixed by the contractors/phone company as soon as they can.)
Nov 09, 2015 | Motorola L401 DECT 6.0 Digital Cordless...
Panasonic DECT 6.0 shows "in use" but it's not. Why?
When I get this error, it's often a problem with the phone line wiring. Sometimes, it is the phone itself.
I like to use a spare corded phone and a new RJ-11 cord to localize the problem. First, try using the spare phone at the jack where the Panasonic base is plugged in. If you get a dial tone with the spare phone, try the new RJ-11 cable with the phone. If there is still no dial tone, then the phone needs repair or replacement.
If you do not have dial tone with the spare phone, try the test phone at another jack on that phone line.If there is dial tone, there is a problem with the first jack. You will need to open the jack and check the wiring. These are either keystones jacks or screw terminals. The keystone type require a special tool to press the wires into the terminal block. This is available at many hardware stores in the electrical wiring aisle (with the keystones and wires for whole house video/telecommunications access).
If you still have no dial tone, find the telephone access box. If you are lucky, that box has RJ-11 jacks so that you can test the line. If there is still no dial tone, contact your phone company. Outside line problems will be fixed by your provider.
If you have dial tone at the access box, you have a wiring problem somewhere inside.You can try to track the wires in any exposed area for signs of damage. You might want to call a professional to check the wires in the wall. Your phone company will do this for a fee.
I hope this helps.
(my own phones gave "Line In Use" when a contractor damaged a wire digging in the wrong spot and when mice got to the underground lines outside. Those problems were fixed by the phone company.)
Jan 29, 2013 | Panasonic DECT 6.0 Expandable Cordless...
My Uniden TRU8885 will no longer give a dial tone or ring when called (I tried using my cell phone). All associated handsets are similarly afflicted. Cleaning peope were here today and must have pressed...
The TRU8885 has a Do Not Disturb feature which will disable the ring on the base and all handsets. To toggle this off, press and hold the DND button on the base. (The key is on the lower left of the keypad, next to the * key). The answering system will turn on when the DND feature is enabled, if it wasn't previously on.
However, this shouldn't disable the dial tone when you call out. I suggest that you check that the base has power. After that, you have to look for a wiring problem. The problem could be the phone, the RJ-11 cable between the base and the wall jack, a wire that is damaged in the wall, or an outside line problem.
First try a new RJ-11 cable; make sure not to use a wired handset cord. After that, I like to use an old corded phone that requires no power adapter to test the line. If the test phone gets a dial tone, then the TRU8885 base has a problem. If the test phone doesn't hear a dial tone, try plugging it into another jack on the phone line if possible. If there's no dial tone (or no other jack), find the incoming service box. If there is an RJ-11 plug in the box, check for a dial tone there.
If you have no dial tone at the service box or can't test the line at the box, contact your telephone company. Most companies will check the line and fix outside problems for free. If the problem is at the first jack, remove the cover plate and look for a loose wire. There are two styles of RJ-11 jacks. The screw terminal type require you to strip the wire and secure it under the correct screw. For the keystone jack type, you do not strip the wire. You use a punch-down tool (available at many hardware stores in the electrical section) to push the wire back into the correct section of the keystone. The little pins will puncture the insulation when the wire is properly inserted to make the connection. See http://www.lanshack.com/wire_phone_jack.aspx for the connection wiring connections. If you have an DSL filter inside your home, replace it if it is faulty. For any other inside wiring problem, you may want to let a professional find the wiring break in the walls. Your phone company will do this for a fee.
I hope this helps.
(I have had dial tone issues from several different causes. A single jack's wire was left disconnected after a service upgrade. Several outages were from damaged outside wiring either from mice chewing or a contractor digging through the wire. With a DSL line, the lightning strike damaged the filter and blocked all of the signals. Recently, a fiber-optic service card failed resulting in intermittent dial tone failures. Except for the first issue which I could fix myself, the local phone company or appropriate contractors fixed the issue for free. However, I don't live in an area where the phone company is trying to stop serving some wired phone customers.)
Dec 29, 2017 | Uniden TRU8885 Digital Answering Machine
My phones are not working at says out of range.
When a cordless phone says "Out of Range" or "Searching for Signal", there are a number of possible issues (assuming you are close to the base). 1) The handset battery may be low and not taking a charge. If the battery is more than a year old (including time spent in storage), replace the batteries for both handsets.
2) The base may not have power or an incoming telephone line signal. Check that the power adapter is warm (power to the base). Use another phone cord (and a second phone (preferably corded) to check for a dial tone). If a second phone has no dial tone, see below for diagnosing a phone line.
3) The phone base has lost the registration information for the handsets. A way to reset the phone is to unplug the power cord (from both the wall outlet and the phone base) and the phone data line and unplug the batteries from all handsets. Wait several minutes then plug in the base power and data cords and then reconnect the phone batteries. You may want to re-register the handsets. This is done by putting the handset in the main charging base for 20 seconds when the handset is fully charged. (See your phone manual) The phone was made by Thomson Electronics for GE; the manual is available here: http://www.home-electronics.net/USER-GUIDES/25952_DOM_EN_CL_IB.pdf .
4) The phone base or handsets are not transmitting or receiving the signals properly. This means that the phone needs repair or replacement. If it is under warranty, contact the manufacturer. Otherwise decide if the phone is worth the repair costs.
If you have no dial tone at the jack where the base is connected, check another phone jack on that line. If you still have no dial tone, find where the phone service comes in. Then open the service box and if the service is fairly new, plug in the RJ-11 test phone and listen for a dial tone. If you can't plug in the phone cord or there is no dial tone, contact your service provider. They will test and fix any outside problem.
If the problem is inside, inspect the visible wires. If you have a DSL filter as part of the inside wiring, check/replace it. If only one jack has a problem, open the faceplate and fix any loose wires. There are two faceplate designs - screw terminals or keystone jacks. For the screw-type, the conductors must be stripped and secured under the screws. For the keystones, the conductors are not stripped but pressed into the terminals with a punch-down tool. This tool is available at many home improvement stores in the wiring aisle. See http://www.lanshack.com/wire_phone_jack.aspx for a diagram of the wiring.
If the problem is not in a visible part of your wiring, you may want a professional to find and fix the problem. Your telephone provider will be willing to do the work for a fee.
I hope this helps.
Jan 20, 2012 | GE 25952 Cordless Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    HELP?Why Does my telephone say connecting?
    Most cordless phones will say connecting when the handset is out of range, the base has no power or the base does not have a dial tone.
    I start my tests at the base and make sure that another phone (preferably an old corded phone) gets a dial tone at that jack. Try a new phone cord to check if the cable is bad. Check if the power brick for the base is warm and that the outlet has power. For some phones, you can reset them by unplugging the base and removing the battery from the handset. Then reconnect the battery and plug in the base. Check if the handset and base can communicate (try the Find Handset option). If needed re-register the handset.
    If the test phone doesn't get a dial tone, then you need to find where you have a wiring problem. Try the test phone at another phone jack. If there is still no dial tone, find the telephone service box (where the phone line comes in). If you have a fairly new service, you will find an RJ-11 jack in the box. Plug in your test phone and check for a dial tone. If you have no dial tone, contact your phone company. They will come and fix the line for free. (If you can't use an RJ-11 cord at the service box, your phone company will test this outside connection.)
    If there is a dial tone at the service box or at one jack and not another, it's an inside wiring problem. Look at any open wires (perhaps in the basement) for obvious damage. Open the jack and check for loose wires. (There are two types of jacks - one wraps the wire around a screw, the other requires a punch down tool to secure the conductors in the keystone. The conductors should be connected to the terminals in the correct order. To see a picture of the terminal connections that are used, see http://www.lanshack.com/wire_phone_jack.aspx . The punchdown tool is available at many home improvement stores in the wiring aisle.)
    If your test phone had dial tone at the original jack and resetting the phone by disconnecting the power did not help, then the phone needs service. If it is under warranty, contact V-tech. Otherwise, you may be better off replacing the unit. These phones are not meant to be user serviced.
    I hope this helps.
    (if you add a comment with the model, then I will check if I can provide more details in my solution.)
    Sep 28, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
    Handset doesn't have dial tone. says check TEL line.
    For this type of problem, you need to isolate the issue. It could be the phone, the inside wiring, or the outside wiring. I like to use an old rotary phone for testing but any basic corded phone should work. Get a new RJ-11 phone cable as well.
    Unplug the base unit and plug in the test phone to that jack. Check if you get a dial tone. (Try a new cable if the initial one doesn't work.) If your test phone has a dial tone, then the problem is isolated to the cordless phone. (If the test phone works with the new cable, do check if Uniden works with that cable.) Modern phones are not designed to be fixed by the consumer. If the phone is under warranty, contact Uniden Customer Service. (Otherwise decide if the costs are worthwhile for you; there will be a significant delay before the phone is returned/replaced.)
    If you do not get the dial tone, you need to track down the wiring issue. Next move to another jack on the phone line and check if there is a dial tone on your test phone. If there is a dial tone, you have isolated the problem to the jack or the wiring to the jack.
    If there is still no dial tone, find where your telephone service comes in to your building. If you can, open the box. Determine the type of connection used there. If you are lucky, you will find a RJ-11 jack for your phone line. Plug in your test phone and check for a dial tone. If there is no dial tone, contact your telephone provider. They will fix this outside problem for free.
    If the connection is not a RJ-11 jack, you will need to call the telephone company so that they can determine if the problem is inside or outside.
    If you do have a dial tone, then the problem is with the inside wiring. Inspect the visible wires for damage. Open the faceplates for the jacks and check for loose wires. There are two types of connectors. Screw type connectors need the wire stripped back a little then wrap around the screw and tighten. The other type is a punchdown jack. To repair a loose wire in this, you will need a punchdown tool. These are often available in hardware/home improvement stores in the wiring section. http://www.lanshack.com/wire_phone_jack.aspx has clear pictures of the wire color to pin pattern.
    You may want a professional to check the wires inside the walls. Your telephone provider will do this for a fee.
    I hope this helps.
    Jun 21, 2011 | Uniden Cordless Phone
    Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
    158 people viewed this question
    Top Uniden Lands Phones Experts
    k24674
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
