Question about Maytag PYE2300AY Electric Dryer
Maytag pye2300ay dryer grinding noise from front
Can you tell me the easiest way to disassemble the cabinet of my Maytag pye2300ay dryer? I want to get a look under the front of the tumbler. I have a grinding noise coming from the front.
  • 548 Answers
You generally have to open up the cabinet from the back by unscrewing the fasteners.
Posted on Feb 06, 2009
Loud grinding noise
These are the bearing that the drum rides on. There are bearings in the back and the front. Replace all of them where you hear the grinding, front or back.
Jan 08, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Making alot of noise going around
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 04, 2011 | Maytag PYE2300AY Electric Dryer
I have a loud noise coming from the bottom right side of my dryer. I am trying to figure out how to open the cabinet up to see what the actual problem is but I can not tell how to open it. There seems to...
maybe the drum rollers,Tim:
http://www.partselect.com/dryer+maytag-atlantis-drum-removal+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
May 29, 2011 | Maytag PYE2300AY Electric Dryer
Dryer heats, drum turns, but makes a rubbing noise.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 19, 2011 | Maytag PYE2300AY Electric Dryer
Intermittent grinding noise as the drum spins. sounds as if the drum is out of balance
replace the belt and the idler pulley for the belt. It has a worn bearing causing this awlful noise
Jan 13, 2011 | Maytag PYE2300AY Electric Dryer
Dryer makes noise when running
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up "
Apr 18, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Dryer Repair
Easy fix.
Open the top cover by insrting a putty knife in the top right and left sides where the top meets the bottom cabinet.
Lay the top to the back.
Remove 2 screws on the right and left front inside corners of the cabinet.
Remove the door.
Replace the belt around the drum and motor pulley.
Re-assemble the dryer.
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
Grinding noise from under tumbler
One of the retaining rings on the motor clamp/drum bearing assembly had probably broken, the machine must be taken apart to access to the motor/bearing assembly and fix the part.
The job should be done by a technician.
Using the machine in this condition can cause more damage to motor/ drum bearings.
Here is the diagram.
here you can buy the parts.
Feb 01, 2009 | Maytag PYE2300AY Electric Dryer
Washer model PAVT244AWW agitation noise
Sounds like the motor is going bad. It will only get louder before it finally stops. There is a device that assists the agitation motion that may be bad or is going bad.
Dec 01, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY drum Belt replacement
HI thanks for your question. its the front that comes off. 2 screws at the bottom of the front. remove them, pull front towards you. thanks
Oct 01, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
223 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
