Question about HP LaserJet 2840 All-In-One Printer
Printing streaks Regardless of printing in B&W or color, the printouts all have streaks through the middle of the page. We just replaced the imaging drum so that should not be the problem.
Most Printers that are laser have a transfer roller or transfer belt. If you have replaced all the drums this can often be the problem.
Posted on Feb 06, 2009
Blue Streaks & "Shadow Prints" on everything?
Mam, try replacing the cyan (blue) image unit may have a bad cyan image unit.
Jan 15, 2015 | Konica Minolta Magicolor 5450 Printer
Vertical streaks but only on first 2-3 pages
replace the image units associated with the color of the streaks
Apr 17, 2017 | Konica Minolta Magicolor 4690MF...
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
HP L7700 officejet printer leaves streaks on black ink lines only. Have cleaned heads repeatedly, changed black and color cartridges - nothing works.
Nov 28, 2009 | HP Office Equipment & Supplies
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
Nov 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
HP DeskJet 970Cse won't print yellow
Here is a link to hp's web site. They will troubleshoot your issue. This link is linked to a page talking about HP Inkjet Cartridges and Media - Missing Color, Wrong Color, or Streaks in the Printout. There are several links in this site to go off of and troubleshoot further. Hope this is helpful:) http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&lc=en&cc=us&dlc=en&product=60097&rule=34749&lang=en Jason
Sep 04, 2007 | HP DeskJet 970cse InkJet Printer
HP LaserJet 2840 All-In-One Printer Logo
279 people viewed this question
Ben Johnson
