Question about Acer Aspire 9300 Notebook
Can't boot and get winload.exe and ntkrnlpa.exe errors
My laptop suddenly refused to boot a while ago. It might be a hardware problem since it mentions something about disconnecting all USB drives when I try to repair. I could enter the advanced boot options using F8 in the beginning but can't anymore.
Anyway I finally got a installation CD which can run repair. I tried to repair but it said it couldn't do it. So I tried to manually copy the winload.exe file to c:/windows/system32/ it worked the second time.
I tried to boot again and this time it said that it had an error with ntkrnlpa.exe. I tried to copy in the same way as I had the winload.exe file but apparently the fiel couldn't be found or copied (something like that.)
I've also tried using a restore point but it said there were none. I tried to use the bootrec/fixboot command but it hasn't worked.
My HD is split into two internal drives C: and D: the system is installed on C: If I do a clean install would drive D: be overwritten too? I was also wondering whether maybe there was a bad connection or a problem with the connection of drive D:
So anyone have any ideas?
  • 7 more comments
  • midiank Feb 06, 2009
    Hmmmm... a restore point? I don't recall it asking me to establish a restore point since the problem started. I have however got some cds with restore points from almost the first month that I had the laptop.
    I'll try copying those files and get back to you with the results.
    They don't seem to be accepting the commands when I try to copy the files. It says the parameters are incorrect or something of the sort. Or it just doesn't accept the command.
    Hmmmm... how do you get to start>accessories>system tools>system restore without logging in?
  • midiank Feb 07, 2009
    I guess I have to do that from the installation cd?
    The stuff which I want to keep is mostly on my D: drive so I guess it should be fine.
    Hmmmm... I've just realised why some things weren't working. I have found out that instead of just having my c: and d: drive along with the cd drive there are two other drives in my computer. I'm not sure whether they're partitions or what they are.
    At anyrate it seems that my computer is trying to boot from a drive x: called "boot" instead of drive c:
    Could it be that this is the problem? Also I can't help wondering how on earth those wierd drives suddenly popped up.
  • Randall  Trahan
    Randall Trahan May 11, 2010
    :) my bad..when you said you tried a restore point I assumed you were in..ok well the last resort is installing the original disc that came with the operating system. Hang on about 15 minutes though, because I am pretty sure that if you load the original disc it deletes the partitions, hence, everything will be lost. Let me ask somebody real quick just to double check..
  • Randall  Trahan
    On the first page after you click on System Restore in Accessories there are two options: one of them is Create a Restore point. Just pick a date and it will reboot and voila you are in the past
  • Randall  Trahan
    Yes, if you go into start>accessories>system tools>system restore in my experience you can establish a restore point then reboot and you're back in time...
  • Randall  Trahan
    Before you re-install and lose everything I want to know about the restore..didn't it ask you to establish a restore poinit? Did you try to establish one?..Also as far as the files to copy over to boot, they are NTLDR, BOOT.INI, NTDETECT.COM and NTOKRNL.EXE, they are on your disc either under i386 or windows. If you can copy those to your C:\ then it will boot. Try those things first and let know.
Hi Midibank,
I have same laptop. It has gone bad and I don't have installation CD. Is there any way if I can buy a copy from you as from Sony website it say they have discontinued it.
Let me know.
Thx.
nk2025 gmail com
Posted on Feb 24, 2009
  • 916 Answers
If you reinstall windows just make sure you do it on the partition it was already installed. If it was not installed in D as long as you do not delete or format that partition you will not lose that data or the partition.
As for your errors you will need to reinstall windows if you cannot repair the already installed partition.
Posted on Feb 06, 2009
How to recover HP laptop from usb or recovery partition when winload.exe not found?
don`t loose time.
back up your files....
format and install windows from a disk!
May 06, 2014 | HEWLETT-PACKARD HP G62 Notebook
\windows\system32\winload.exe missing or corrupt 0xc000000f for toshiba
This is usually a fatal error.
The hard drive has either a damaged sector or the windows file is damaged/missing. Try pressing F8 just before it tries to boot and select repair or restore.
Dec 26, 2013 | Toshiba Satellite Computers & Internet
TOSHIBA LAPTOP WILL NOT BOOT KEEPS DISPLAYING ERROR MESSAGE THAT SAYS,FILE:/WINDOWS/SYSTEM32/WINLOAD.EXE ,STATUS:0xc000000
Try going into safe mode with command prompt enabled. (F8 on bootup). In command console type chkdsk /f /r and enter y for yes at the prompt. Wait for it to finish. If that doesn't solve it try typing fixmbr.
Sep 29, 2013 | Computers & Internet
":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
Jan 16, 2013 | Acer Aspire 5610-4648 Notebook
Can i386 unidrv.hlp for xp pro sp 3 be downloaded from Microsoft?
  1. Insert the Windows XP startup disk in the floppy disk drive, or insert the Windows XP CD in the CD drive, and then restart the computer.
  2. Click to select any options that are required to start the computer from the CD drive if you are prompted to do this.
  3. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  4. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  5. When you are prompted, type the Administrator password. If the Administrator password is blank, press ENTER.
  6. At the Recovery Console command prompt, type the following lines. Press ENTER after each line. cd system32
    ren ntkrnlpa.exe ntkrnlpa.old
    ren ntoskrnl.exe ntoskrnl.old
    cd "c:\windows\driver cache\i386"
    expand sp2.cab -F:ntkrpamp.exe c:\windows\system32
    expand sp2.cab -F:ntkrnlmp.exe c:\windows\system32
    cd c:\windows\system32
    ren ntkrpamp.exe ntkrnlpa.exe
    ren ntkrnlmp.exe ntoskrnl.exe
  7. Type exit to quit Recovery Console. Your computer will restart.
Or go to http://www.ventrilo.com/dlprod.php?id=1 and click on agree.
Nov 03, 2010 | Epson Stylus Photo EX InkJet Printer
New pc core i3 intel orignel mother board DH55TC DDR3 2+2 RAM DVD R/W VIP SMPS PROBLEMI NSTOL WINDOWS 7 &VISTA BOOT CD 1 STEP :- WINDOWS IS LODING FILE STEP :-2 ERROR LODING WINDOWS 1 PLS INSURT CD AND...
Here is a possible fix found at the Microsoft knowledge base .
read and follow the instruction given.
If you are not comfortable with the registry fix then you may have to call the mother board tech support for further instructions but this is found in the Windows 7 environment or operating system.
Article ID: 927392
Apr 01, 2010 | Computers & Internet
Winload.exe problem
is this ur oprating is on other than c:\ drive if yes then then u r not able to do to stop this error simply move ur data then install on the c
: drive then after u can create the clonr without error
please vote for me
May 19, 2009 | Microsoft Windows Vista Ultimate Edition
Acer 5520 notebook startup issues
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Dec 23, 2008 | Acer Aspire 5100 Notebook
Ntkrnlpa.exe problem
Please boot your laptop from your windows CD and select repair the windows. ** Please don't select format the hard disk, else all your data will gone.
Jul 31, 2008 | Dell Computers & Internet
Acer Aspire 9300 Notebook Logo
296 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
