Question about GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket
GE front loader shakes when trying to spin
One month old ran go 2 weeks called ge service about shake found one shipping block left in unit. They are saying the shake is coming from bad floor, what do you think?
  • 548 Answers
Try putting either a piece of plywood under the machine so that all 4 legs are standing on it or using plastic floor protectors that fit under each leg to see if you can get it to be more level. Have you ensured that each leg is in full contact with the floor?
Posted on Feb 06, 2009
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
My front loader shakes.. when in the wash and spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 13, 2010 | GE WSXH208A Front Load Washer
GE Front Load washer shakes whenever any type of load is put in. GE service has been out at least 4 times and say that its fine..perfectly level, etc
All front loaders shake to some extent. It depends on the balance of the load. It is especially evident in the spin cycle due to the high speeds. Also these machines are best placed on a solid cement floor. They can shake an entire house if on the first or second floor and the floors are not well reinforced.
Feb 25, 2010 | GE WSXH208A Front Load Washer
GE Front load GCVH6600 Shakes all over the place on spin cycle
Wow...does it sound like it's about to take. You can hear it all over the house even with the door to the room closed? We have the same reason. THis started after a bout of lice in the house and we were doing many loads a day for a while. Help!
Jun 28, 2009 | GE WSXH208A Front Load Washer
Constant resetting
it may have a blocked up pump so keeps trying to spin out water.But your under warrenty.call GE they will send some one out to fix that for you
Dec 31, 2008 | GE WCVH6260F Front Load Washer
GE WHRE5550HWW Excessive Shaking in spin cycle
Replace your stablizers, one of them has broken.
Dec 16, 2008 | Washing Machines
GE front load washer can't handle more than a single shirt at a time or won't tumble or spin
Front load washers have an auto water level determined by the weight of the clothes placed in the washer.
If that sensor is malfunctioning the washer may not run !
Unfortunately I think that its time to spend $75. and have a trained GE laundry tech with hands on diagnostic experience remedy the problem. Rather than you spending tons of your hard earned money swapping parts!
I agree with you on that point!
I understand this is not as complicated as a jet engine.
And you tried your best,but some times it is more
cost efficient to let a surgeon fix my hernia while I'm relaxed and under anesthesia, than try to fix it myself!
If My jet was broken, I would not risk flying it after I fixed the problem because I am an appliance man!
I would prefer my life in your hands with your expertise !
Please cut your self a break and call service. You may find it interesting, and fascinating yourself to see what the problem was!
Bless you, and let me know what was the end result!
I believe if I was there with hands on, I would solve your problem!
Please give me a good rating before you sign off, for my rational and calming advice
ngafm
Aug 26, 2008 | GE Energy Star WCVH6260F Front Load Washer
Frigidaire front-load stackable washer has violent shaking cycle
The Shipping bolts need to be removed from the back of the unit?? they go thru a plastic sleeve once the bolts are out you can twist the plastic peice to remove them completely I think there are 3 of them
Jan 24, 2008 | Frigidaire GLTF1670A Front Load Washer
Our washer shakes badly at the spin cycle
look on the back and take the shipping pins out there are 4 bolts on the back of the machine the only only ones that are 1/2" socket size or 7/16" pending on the machine.
Jan 04, 2008 | Washing Machines
GE Energy Star 3.7 IEC Cu. Ft. Front Load Washer with Stainless Steel Basket Logo
119 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
