Question about Singer Quantum XL-1000 Computerized Sewing Machine
Singer 301A stitch jam
I recently purchased a beautiful Singer 301A. However, I can't seem to get the stitches to stitch out smooth--- rather it bunches up and doesn't move smoothly with the fabric. I pull the fabric out only to find gobs of stitches on the bottom. I am researching the web for possible solutions. I bought the machine because of its great reputation for workmanship and long wear.
Thanks
Deborah
    Scholar:
  • 69 Answers
It sounds like your feed pressure and tension are both off. Try sewing with out thread. If the fabric goes all over the place, you need to adjust the feed pressure (the screw on the top of the machine). Tighten it down until your fabric feeds evenly. If the fabric is bogging and not feeding, you need to loosen it.
Your tension sounds like it is off as well. Make sure it is set around 2-3 and check your tension disc, make sure there is no thread in between the disc. If so, remove it. Now, thread the machine and check the thread through the needle. It should pull out quickly and smoothly. Now, put the presser foot in the down position and pull the thread, it should have some resistance. If not, your tension is set too low. Turn it up a little and try sewing. If the thread is still knotting up, you can turn the tension up to about 5, if that does not correct the problem, you will need to adjust the tension dial itself. To do this, press on the numbered part of the dial and it will push in, then turn it to a lower number, release and make sure it has locked back into place. Then adjust again as I previously instructed.
Posted on Feb 07, 2009
Singer 756 zigzag timing is off
The machine may be slightly out of time so it works in straight stitch but not zig-zag.
Oct 23, 2017 | Singer Sewing Machines
Singer 301a that picks up thread on the wrong side
Make sure the flat side of the needle is facing back.
Jan 29, 2010 | Singer Sewing Machines
I baught a singer handy stitch sewing machine from a thrift store and the manual is not with it i need a list of parts and a instruction manual. it is one that is from t v i also do not know if all the...
Hello, Bryans8 -
I have not yet found a manual for a Singer Handy Stitch. However I found some YouTube videos which are descriptive:
Part 1 - How to Use the Singer Handy Stitch
https://www.youtube.com/watch?v=G05dWewvEK4
Part 2 - How to Use the Singer Handy Stitch
https://www.youtube.com/watch?v=XKd2B32-1aY
Part 3A - How to Use the Singer Handy Stitch
https://www.youtube.com/watch?v=J5dzmeRPXhw
Part 3B - How to Use the Singer Handy Stitch
https://www.youtube.com/watch?v=3F-BN7GtDis
Part 4 - How to Use the Singer Handy Stitch
https://www.youtube.com/watch?v=DhiZ6pZ8LEc
I also found these instructions (not from Singer):
https://www.thriftyfun.com/Threading-a-Handy-Stitch-Machine-2.html
This is a link to other (not from Singer) instructions:
https://www.ehow.com/how_7313842_instructions-singer-handy-stitch.html
Plus more instructions (not from Singer):
http://www.ebay.com/gds/How-to-Use-a-Handy-Stitch-/10000000178758752/g.html
Best wishes.
Jan 20, 2018 | Singer Sewing Machines
Singer 301A needle breaks
do you have a book, refer to threading. This machine threads differently than most, threads like a 221 featherweight. Needle goes in backwards, and threads backwards. in wrong and you can have problems, also threading can cause your problem if you have missed tension or a thread guide. great little machine
Jun 01, 2009 | Singer Quantum XL-1000 Computerized Sewing...
your machine threads from right to left. the needle flat spot faces left. big loopy things means that the upper part of the machine is not threaded properly. as far as the needle hitting the bobbin case, it sounds as if someone removed the hook (part that holds the case) and put it back on 180 degrees off.
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Mar 15, 2009 | Singer 3116 Simple
Back side of fabric stitch is not smooth
This is caused by inadequate tension on the top thread make sure there are no broken threads between the discs of your upper tension and it should be set on app #4
Nov 16, 2008 | Singer 132QRFB Mechanical Sewing Machine
Singer Quantum XL-1000 Computerized Sewing Machine Logo
200 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
