Question about Brother IntelliFax-2820 Laser Fax
TONER LIFE END APPEARS ON LCD
I'VE GO A BROTHER FAX MODEL # FAX2820. AFTER I REPLACED THE TONER WITH A NEW ONE, TONER LIFE END KEEPS SHOWING UP ON THE LCD DISPLAY. WHAT DO I NEED TO DO TO GET MY FAX MACHINE WORKING AGAIN
  • 215 Answers
Try opening front door, press "options" then "start" then "1" and "0". if screen shows accepted, you're good to go. close front cover.
hth,
razors
Posted on Feb 06, 2009
    Champion:
  • 320 Answers
IF YOU HAVE THE MANUAL THAT CAME WITH THE MACHINE IT WILL TELL YOU WHAT TO DO TO CLEAR THE MESSAGE, OR YOU CAN CALL BROTHER AT 9087041700
Posted on Feb 07, 2009
Have replaced toner, but toner life end keeps showing. I did not remove the white mylar strip, the unit snapped in and we cleaned the cleaned the primary corona wire. What can I do?
try this one turn off the machine for 10 mins.then remove toner then shake just to obtain the toner clean and put it back then turn it on.
Jan 09, 2011 | Brother IntelliFax-2820 Laser Fax
I change the drum for my fax machine, but it still says Toner Life End... and it is a bran new cartridge?? I tried turning it off and on, and unplugging it... but it still says Toner Life End... how do i...
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Brother IntelliFax-2820 Laser Fax
I am changing the ink cartridge i put the new one in and it keeps saying End of life and it has a new cartridge what do i do
Here is the solution that will reset the count and allow your fully functional toner cartridge (the one the printer tells you is empty) to continue to work.
Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.
You have to do this with a long pause or the system will reset and you will have to start over.
Good luck.
May 24, 2010 | Brother DCP-7020 All-In-One Laser Printer
I replaced already new toner cartridge for my brother fax machine mfc-7220 but still the on screen message is appearing on the display "TONER LIFE END". Pls help me to solve this problem. Tnx and God bless...
I replaced already new toner cartridge for my brother fax machine mfc-2820 but still the on screen message is appearing on the display "TONER LIFE END".
Apr 12, 2010 | Panasonic KX-FL541 Plain Paper Laser Fax
Said low toner cartridge. Replaced cartridge,
what is showing toner life end ? rajcanon007@yahoo.co.in
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
4. Press 1,0 .
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner and it comes up with Toner Life End
Im think you leave the cover open and hold down clear
Jan 21, 2009 | Brother IntelliFax-2820 Laser Fax
Toner low, tone life end
There is a gear on the left hand side of the toner to reset the toner count this can cheated be rewinding it. Yes the design is to stop the refillers or at least slow them down a bit. If this fails purchase a new genuine toner but I have seen problems with the switch that resets the toner (Either the spring on the switch has popped off or the main board has failed).
Jan 10, 2008 | Brother MFC 7420 All-In-One Laser Printer
Fax machine 2820
Make sure that you are not using generic supplies. Using generic supplies or supplies that have been refilled will cause the unit to give false errors. There is white piece of plastic inside the semi circular opening, if you do not see a white semi circular opening it is either a generic toner or starter toner and you will need to replace the toner with a authentic toner. You may try this also: 1. Remove the drum and toner, separate the drum and toner and then rock the toner from side to side. 2 Put the drum and toner back together and clean the corona wire ten times. 3 Put the drum and toner back inside the machine and close the cover, if you still have toner life end try this: a Open the front cover b press the options key, the LCD will say "replace drum?" c press the start key. and then press 10 on your dial pad. the display should say accepted for about 2 seconds and then say cover open. d close the cover, if the display still has toner life end, you will need to replace the toner
Oct 03, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
401 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
