Question about Ricoh Aficio SP C410DN Laser Printer
Ricoh Mp2050c When the printer prints from a locally loaded driver the printer prints fast. when printing from a driver on an application server(Reynolds&Reynolds) the printing is slow and pauses substantially between pages like 20 seconds and longer 45 seconds when changing to a different paper tray within the same print job. thanks for your help.
    President:
  • 903 Answers
The problem sounds like a difference in the settings between the two drivers. Can you compare the two drivers' properties? Maybe the server's driver is set for different spooling options. Is the server handlilng other functions at the same time?
Posted on Jun 05, 2010
How do I print envelopes on Ricoh Aficio SP C430 DN?
You will have to change the paper tray settings on ricoh to match the settings in your driver too. Also being a Ricoh you may have to create a custom size with in the driver to get it to work. What size are the envelopes?
Apr 18, 2016 | Ricoh Office Equipment & Supplies
Does this printer print envelopes
Information and drivers for your printer can be found here:
http://www.ricoh-support.com/enduser/downloads/advsearchresult.asp?type=main
Beginning on page 33 of the PDF of the Hardware Guide there is a description of the paper types that can be printed.
Yes this printer can print envelopes. On page 37 of the PDF there is a description of how to load and print envelopes.
Trust this is helpful. Please vote.
Dec 18, 2010 | Ricoh AficioSP C221N Laser Printer
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1232C rpcs When I try to print the red light appears on the printer saying 'load by pass tray' even though I have selected Auto tray. Normally the machine prints fine.
when you selected auto tray was that in the driver or microsoft settings ? microsoft settings will overide the copier settings driver. look under file then page setup to see what it is set for.
May 20, 2010 | Ricoh Aficio 1232C Color Copier
My printer prints very small laters
>what applications or documents are you printing?
>this could be application specific or the printer driver is incompatible with the application. you can check by printing other application or documents.
>you can also install generic driver, go to printer and faxes folder add a printer, add a local printer and select usb port, select hp as manufacturer and select deskjet 990c as your print driver
>you can also try to go to www.hp.com select support and drivers and then download the latest driver for this printer and install it
Sep 23, 2009 | HP DeskJet F380 All-In-One Printer
Can not print to network printer
Do you mean you can ping it? If you can't, then disregard, my instructions below
You downloaded the latest "Vista" driver? then you went to"add Printer", Selected "Local Printer", then "create new port", select "standard TCP/IP port" typed in the proper Ip address of the printer? The wizard should find it and show it as using "Ricoh type C adapter" or similar, (if it moves on to the "select generic adapter" something is wrong) select have disk, and browse to the location of the unzipped printer driver, and install
Feb 26, 2009 | Ricoh Aficio 1035 Copier
LAN PRINTING NOT WORKET ON RICOH 1600LE
use an updated driver version for this machine on ricoh-support.com, another solution is using pcl5 driver as this one does spooling at computer and not machine...
Dec 06, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio SP-C210SF
sounds to me you are using the "wrong driver" double check the driver and the OS you are using.
I would also turn the printer off and clear all print jobs from the print que and restart. After loading the new driver do a test page from the driver.
Aug 15, 2008 | Ricoh Aficio SP-C210SF Printer
Problem with printing document footer text on RICOH SP C811DN
Check the paper size settings and orientation of the driver from the Control Panel, and that match to the paper size in the printer's trays.
Good luck and please rate me, thanks.
May 28, 2008 | Ricoh Aficio SP C811DN-DL Printer
No PPD available for mac
I used the Gutenprint driver for the Ricoh 220. It seems to be working fine.
Oct 08, 2007 | Ricoh Aficio BP20N Laser Printer
Ricoh Aficio SP C410DN Laser Printer Logo
462 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
