Question about Lexmark X3470 All-In-One InkJet Printer
Changed cartridge and printer says cartridge incorrect
Printer says cartridge incorrect
  • dlyles Feb 13, 2009
    Same here
  • 62 Answers
There are a small number of #23/#24 cartridges that are not properly recognized by the printer. Lexmark has a firmware upgrade to correct this issue.
The upgrade for the X3470 is available from Lexmark at: http://www.downloaddelivery.com/downloads/misc/Firmware_F061909_3430Series.exe
To install the firmware upgrade,
  1. Make sure the printer is ON and connected with a USB cable.
  2. Download and run the appropriate firmware upgrade for your computer.
  3. Be sure not to disconnect or power off the printer until the upgrade is complete
When the update finishes the printer will restart and will accept the cartridges. Please contact Lexmark support if this does not fix the problem.
This works for 3400 Series printers. A similar patch is available for the X3550, X4550, and Z1420 models. See http://bit.ly/LoXxv
Posted on Jun 25, 2009
4 Suggested Answers
SOURCE: Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Posted on Jul 06, 2008
mnewelski
  • 8 Answers
SOURCE: Have a error message left cartridge incorrect
Hey!
Are you using Jet Tec ML32 Cartridge re-manufactured cartridges or genuine Lexmark Cartridge?
If it is the Jet Tec cartridge then it is known to be faulty - purchase a Lexmark cardridge and you should be fine.
If it is the Lexmark Cardridge then I would recommend taking all of the cartridges out, turning the printer off (from the power), turning it back on, inserting the cartridges again and checking if it works.
If none of the solutions work, then your cartridge is damaged and should be replaced.
Cheers,
Matt Newelski
Posted on Dec 08, 2008
don_farr
  • 1018 Answers
SOURCE: refilled cartridge , printer says right cartridge incorrect
Lexmark builds intelligence into their cartridges and printers to prevent the use of refilled cartridges.
Lexmark has never approved the use of anyone else's ink for their printers primarily because there is no way to prove the quality of the ink.
Please purchase a Lexmark cartridge.
Posted on May 09, 2009
What is the cause of my printer o be saying change cartrige when i already change it
It may be some reasons:
1. Cartridge incorrectly changed. Just be sure to remove and set the new cartridge correctly.
2. No good connection. Sometimes ink spills on the cartridge connectors OR the protective plastic still set on the cartridge. Clean the connectors with a soft cloth and be sure to remove the plastics - see installation guide on cartridge.
3. No procedure was done. To change a cartridge correctly, some printers require a procedure for it, be sure to read the user manual how to change cartridge.
Other non-common issues: bad new cartridge, faulty printer, software or firmware glitch, etc,
Apr 15, 2010 | Brother MFC 420CN All-In-One InkJet...
Incorrect print head installed
If you have changed the cartridge check the Number
if not then remove the cartridge and clean the contacts of both printer and cartridge
Oct 05, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Printer says cartridge incorrect, but is the right one...what do I need to do?
The upgrade for the X3430 is available from Lexmark at: PC: http://www.downloaddelivery.com/downloads/misc/Firmware_F061909_3430Series.exe Mac: http://www.downloaddelivery.com/downloads/misc/Mac_MCC_J062309_01.Zip
To install the firmware upgrade, 1. Make sure the printer is ON and connected with a USB cable. 2. Download and run the appropriate firmware upgrade for your computer. 3. Be sure not to disconnect or power off the printer until the upgrade is complete
May 10, 2009 | Lexmark MFP-X3470 All-In-One InkJet...
Lexmark says inncorrect cartridge
chage both the cartridges as u have changed 1 also change another as its not getting detected.
Dec 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Hey!
Cheers,
Matt Newelski
Dec 08, 2008 | Lexmark X5495 Printer
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
Jun 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lexmark X3470 All-In-One InkJet Printer Logo
790 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
