Question about NEC MultiSync MT1000 Multimedia Projector
NEC Multisync MT1000 Projector - Green Hue
I have a NEC Multisync MT1000 Projector that works fine except it has a green hue cast over image.  The bulb has around 1500 hours of use - is this a bulb problem or something else?
Thanks in advance!
  • 25 Answers
The main problem I've seen with NEC optical blocks is that the UV filter for the blue panel will turn brown and opaque after time, blocking most of the 'blue' from reaching the screen. It's similar to putting sunglasses on. I've had success by simply removing the filter from the optical block, and replacing it with the red or green filter from another failed optical block. It will work fine without the filter, but I'd never suggest doing that. :)
Posted on May 01, 2013
  • 93 Answers
Its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Posted on Feb 08, 2009
GREEN GLOW on NEC VT 770 projector
That will be a worn or damaged green LCD unit. If still available, extremely expensive.
Jun 22, 2017 | NEC VT770 Multimedia Projector
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Nec projector vt 660
could be bad bulb is it setting in right is coler wheel freeley moving
Oct 06, 2008 | NEC VT47 Multimedia Projector
Projector Problems
There is some problem in your LCD Panels. Service the optical unit ant retry.
regards
Viren
Jun 30, 2008 | Office Equipment & Supplies
Mitsubishi XL8U Projector
Hi terry2421
No this is not the bulb. You will have to get the Mainboard repaired at a service provider. Losing signal and a discolouration showing up is a clear indication of a faulty Mainboard.
Get a quote first , because some service providers overcharge on these sort of repairs. The most you should pay is $150.
May 20, 2008 | Mitsubishi XL8U Multimedia Projector
Problem: Green colour cast
Problem resolved by swapping the video cable, simple really!
Feb 13, 2008 | Sony VPL CS5 Multimedia Projector
Too much green
It is unlikely that the sudden appearance of a green hue is due to the printhead or drivers going belly up. If the images on photo paper are OK when using the plain paper setting but have a severe green/blue hue when using the higher photo settings it is likely that the photocyan cartridge has been contaminated with cyan ink. Throw the contaminated PCyan cartridge away and fit a guaranteed photocyan cartridge (OEM or compat). Carry out a deep clean and run several plain papers through on a high photo setting. The green hue will gradually disappear.
Dec 06, 2007 | Canon PIXMA iP8500 InkJet Photo Printer
NEC MultiSync MT1000 Multimedia Projector Logo
510 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
