Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
Posted on Feb 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag neptune front load washer wont start when button pressed
Plugged in, door closed, detergent added and detergent door closed, dial moved to correct setting and other button selections pressed (water temp, etc).It seems to be an intermittent problem. Some washes start right away, some I go back later and start. This time, it will not start at all.
Anonymous
Level 2:
Scholar:
  • Expert 99 Answers
  • Posted on Feb 06, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
99
Questions
0
Helped
35995
Points
170
This is joyce
first lets start simple unplug the machine and leave unpluged for 1 min. replug back, see if this solves the problem.
thanks,
joyce
My Maytag front load washer , powers up and lets me change the settings, but when I press the start button , it beeps and displays d5 and wont start??
this fault code ind a door lock problem ,hence this is why it wont start , it thinks the door is not closed , id say the door latch mech. needs service
Why won't my maytag neptune front loading washer will not start?
Check out the door switch to make sure that it closes when you latch the front door. If it does not close the machine will be inoperative - safety measure.
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    May tag Neptune showing codes
    Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
    Do
    Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
    FL
    The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
    Sd
    The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
    PF
    The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
    Nd
    The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
    LO
    The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
    Lr
    The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
    NF
    The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
    Od
    The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
    Other Codes
    * If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
    Hope this helps (remember to rate and comment this answer).
    3helpful
    2answers
    If you get the FL how do you get the door to open??
    1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
    2. Do
    3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
    4. FL
    5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
    6. Sd
    7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
    8. PF
    9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
    10. Nd
    11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
    12. LO
    13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
    14. Lr
    15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
    The lights go on, but washer will not start.
    door not closed try open door and then closing again
    Maytag neptune front load washer says control lock and wont start and buttons wont work
    unplug the washer for 15 minutes then:plug it back in and, restart a few times in a different cycle canceling each time until the door opens. Do this only if the tub is not full of water if it is let me know and, i'll show you how to drain the washer first before we try to open the door.
    Won't Start - Beep-beep-beep
    unplug it then plug it back in to see if it helps
    Front load washer doesn't spin
    My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
    Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
    Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
    Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
    If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
    Top Maytag Washing Machines Experts
    ZJ Limited
    ZJ Limited
    john h
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
