Back to:
Tags:
Intel Denki Fan CPU Fan
Recommend a FAN for the Pentium Pro 1MB 200MHz
By Riddle - usenet poster
Anyone recommend a fan for the Pentium Pro 1MB 200MHz processor.
The ambient temperature has increased in our office, and the DEC
Digital Servers are suffering, and alarm at Pentium Pro temps of 80
degrees C (max spec limit). These are Quad servers so it doesn't help,
but we've reduced them to duals and it doesn't make alot of
difference.
We tried fans we've purchased locally and via eBay, and the cheap poor
fans melt with the heat. (these servers our on 24x7).
My guess is that the fans are too close to the small heatsinks, and
heat up, and it warps the bearings or something.
Anyone suggest a CoolerMaster fan, if these will fit or other
Sanyo Denki originally supplied heatsinks with Retail Boxed Pentium
Pros which seem to work very well, not too sure if these would work on
1MB chips, we have these on local workststaions at 256/512 cache, with
the bump on the chip.
I don't know if Sanyo Denki still supply these!?
AJ
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Melissa
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks for the good advice.
The DEC Servers have primary and secondary fans which kick in. Air
flow is okay through the servers.
The problem is ambient air temperature in the computer room. It was
30 degrees today, and 34 degrees C outside!
Temp Heat wave in the UK!
Air Conditioning is the only answer, but we've been quoted ??6 - ??7,000
UK GBP.
Which is very expepsive for a few days in the year when we have these
freak heat waves!
We may examine the replacement of the servers, with new.
We also have stocks of spares for the servers!
Thanks to all that replied.
Regards
AJ
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Recommend a FAN for the Pentium Pro 1MB 200MHz:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Kim1
Rating: 0%, 0 votes
Depending on how much clearance is in the case above the CPUs, try putting
in longer screws with spacers between the HS and fan. Maybe this will help
temporarily to stop the fans from overheating from contact with the
heatsink. Rubber washers of some type, or those old motherboard case mounts
washers.
The Socket 8 CPU heatsink is huge and will certainly accommodate almost any
CPU fan out there. Clearance is the problem.
Otherwise, more case fans can be used to move more air through the case
helping the CPU fans. Maybe you can direct air at the CPUs with a jury
rigged case fan pointing at the CPUs. If there are no free case fan opening
try, slot fans, bay fan, etc to move more air. Replace the case fans
existing with much stronger ones. Also check that you Power Supply fans are
doing their job. Maybe there are shot or so full of dust they are working
inefficiently.
My guess is the cooling in the servers is not working properly, the problems
with the CPU fans is a symptom, not the cause. There servers seem to have a
cooling problem. Removing CPUs from a quad to two is a great drop in heat
so think about the box as a whole, not the CPU.
If your Digital servers are in a closed locked room, increase airflow to the
room. You can get a water cooled circulating air-conditioner installed to
cool the room but expensive. Why has your office ambient temperature
increased? Temp heat wave or permanent problem?
Last, time to upgrade those old servers ... What if a major system
failure?? Do you have a service contract? Using such old technology in a
production environment is a recipe for disaster unless you have a service
contract with someone reliable in old tech or you had better have lots of
spare parts on hand and maintain your own spare parts inventory. I have
seen production lines go down because they were running on an old XT PC that
finally died after 10 years and no service contract, no one knows anything
about the equipment. A major NHL hockey team rink scoreboards ran on old
386 PCs that crapped out and they went scrambling for parts/replacements in
the used computer stores as way too old for anyone to service. Funny how an
old 386SX system went for a couple of $100 to someone desperate a couple of
years back. All too typical in today's world, it takes a disaster to get
something done that should have been replaced long ago.
If I were you, I would get the budget to replace that server(s) with a
modern one. Normally, you never get a chance to avoid disaster by having
warning signs, you certainly have some now and if lucky will remove the
threat to your company. Anticipate instead of react to the problem.
You could probably replace all your Digital servers with one 2+ GHz system,
reduce operating costs (electricity etc), etc.
Thank You!
Solution #3
Not Rated (0)
pandamama
Rating: 0%, 0 votes
Try calling an AC company, fans wont help much if the ambient temps rise
too high.
Lane
Thank You!
Solution #4
Not Rated (0)
Duke
Rating: 0%, 0 votes
yes Pentium Pro is a Socket 8.
AJ
Thank You!
Solution #5
Not Rated (0)
Hart
Rating: 0%, 0 votes
I don't think a socket A HSF will work, I just looked at an old socket 8
(Pentium pro)CPU, and it is much larger than a socket Athlon or Pentium 4.
James
Thank You!
Solution #6
Not Rated (0)
pandamama
Rating: 0%, 0 votes
Pentium Pro is socket based isnt it?
If it is try a socket A heatsink on them, get a cheap one, and it will be
massivley over specified for the application.
Thank You!
Can you Help with these System Cooling problems?
System Cooling
i replaced the drivebelt and now brakes do not work. i...
System Cooling
Whats the best heatsink/fan/pipe product on the market for...
System Cooling
87 4x4 suburban won't start has spark, fuel pressure,...
System Cooling
n?o consigo configurar o outlook no meu pc atravez do meu...
Loading problems.
Repair Service
Find System Cooling Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
