Question about JVC SIRIUS Satellite Radio Interface for Select CD Decks and A/V Receivers
Satellite receiver not responding
My receiver not responding I can turning on, it has power on the receiver screen isn't clock time or channel number just on digit I can turn on same
  • 4,806 Answers
Hi there
Unplug the receiver from the mains for around 10 minutes then try again, also place new batteries in the remote.
Good luck and thanks for using Fixya!
Posted on Feb 06, 2009
    President:
  • 2,559 Answers
You need to unplug it for about 30 minutes so it can reset.
    Sergeant:
  • 326 Answers
Reset the receiver again and try if its responding again
How do you set time/date?
Hi, do you have the MiniTuner module in the radio? You need that in, and the antenna connected facing the SW horizon. Turn on to SATellite. Adjust antenna so that you can hear Channel 1 clearly. After you hear channel 1, the satellite will send a time signal. Then go to MENU, select Adjust time and pick your time zone and if you are on Daylight Savings time. Then, menu to exit out. Your satellite signal will keep the time updated when in Satellite mode.
I don't know if that will also set the regular clock too, or just only the time while in satellite mode. Let me know how you do with it.
Aug 19, 2014 | Timex TMX1 Satellite Radio Receiver
Sharp TV
Without the specific model number, I can't give you teh exact sequence, but you need to setup the set to only enable channel 3. Work your way through the menus to select channel 3 as your "favorite" channel. Disable all of the others. The set should then turn on as channel 3 at all times. Feel free to post the model number and I'll pass along more details.
Dan
Mar 20, 2008 | Televison & Video
GE spacemaker range model number jmp28g0r1wh display goes blank and oven turns off
the model number isn't correct.check and send the model number again.if you changed the sensor this should take care of the f3 error code but the clock shouldn't go blank and oven stops.like i say your model number doesn't show up as a good number,if this machine has a fan in it you could have a bad fan motor,the fan cools off the electronics and if it isn't working the clock assy. can get hot,damage it and it will do this,also i've seen on some models there's a screen where the fan is and dust gets stuck on the screen and the fan can't blow any air,i'm just telling you what i've found before but it sounds like the clock assy. is heating up and shutting down,if there isn't a fan in your model it sounds like you have a bad clock assy.if you send the model number i can look it up for you.
Nov 15, 2011 | Kitchen Ranges
I have a 2007 dodge ram pickup with sirius already built in. When I hit the sat button it is on channel 184 and there is no sound. I cant change the channel and the volume control will only let me turn it...
Hit eject button and clock button at same time. Ur Id number will show up. It will only show 4 numbers at a time. Hit seek button 2 more times to get the rest of the numbers
Jul 07, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
How to set the clock on vcr/dvd.
Make sure the antenna//cable TV connections are correct. Channels are set. If this unit is connected to a cable/satellite box, select the local PBS station on them to set the clock automatically.
There's an Auto Clock Setting. "This Unit can set the time and date automatically by reffering to a PBS station.". But I never had to do that, I just went to Setup and it already knew what the date and time was.
"Note: The clock may set itself automatically after you connect the antenna/cable signal and plug in the power cord. Only the analog PBS channel signal is effective for auto clock setting. The unit receives the clock data at 12:00 A.M./P.M. from the PBS channel when the power is off.
1 Press [SETUP] and use the up and down arrows to select "General Setting", then press OK.
"General Setting" menu will appear.
2. Use up and down arrows to select "Clock" then press OK.
"Clock" menu will appear.
3. Use up and down arrows to select "Auto Clock Setting", then press OK.
4. Use up and down arrows to select "Auto" then press OK.
5 Press SETUP to exit.
6. Press STANDBY-ON to turn off the unit.
This unit will search for the time only when the power is off. Leave it off for several minutes to give this unit time to set the clock.
If the unit chooses an incorrect PBS channel, set the PBS channel manually by following the steps below:
1. Select "Manual" at step 4, then press OK.
2. Use [the number buttons] or up and down arrows to enter your PBS channel number, then press OK.
3. Press SETUP and turn off the unit.
If this doesn't work, let me know and I'll type up the instructions for what to do if you need to actually set the clock manually.
Mathis...
Feb 17, 2009 | Philips Magnavox DVD/VCR Dual Player
I can't turn on my satellite receiver, it has power on the receiver screen is not a channel number or clock time just one digit
Is this a Pansat receiver? If so or not then you will have to find out about Jtagging your receiver. Maybe because bad script or just cloning you have to jtagg first then rescript.
Sep 12, 2007 | Audio Players & Recorders
Satellite receiver
dont need factory to reflash.
turn of set at plug.press and hold backup on set(keep pressed)
turn on at plug.keep backup pressed for about 15 seconds.all lights on set will flash.if you have tv tuned to set screen will display updating system.dont turn off.when lights on set go off(about 10min later)set is reset(flashed)Press power on remote sky will restart like new.
Sep 03, 2007 | Panasonic CR-SRF100 SIRIUS Radio Receiver
was you satellite tampered with? If so then it could be an eeprom jam!
Sep 02, 2007 | Audio Players & Recorders
Search internet for JTagging sonicview receiver. You will need special equipment.
JVC SIRIUS Satellite Radio Interface for Select  CD Decks and A/V Receivers Logo
157 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
