Question about Sherwood RV-7050R Receiver
Will not produce sound through the top end of my speakers,
I was wondering why everything was sounding Mono, then i realized the sound output to the speakers is only being transmitted through the Main speakers, none of the top end is working on all four speakers
  • 4,234 Answers
While this may sound strange, it is not likely the receiver that is the probem, at least at this point. Remove the "tweeters" from the speakers and measure across the two leads. You should read continuity. If not, then the tweeters need to be replaced. I believe that you may have blown the tweeters.
Posted on Feb 07, 2009
When running live sound in mono should I pan everything to 1 channel or use splitter and pan everything to middle coming out both channels
Frank, What exactly are you trying to accomplish? Are you attempting to do a single mix with only 1 output/speaker? Depending on your personal preferences, if you are using multiple outputs, then you should be running everything in stereo. It is more difficult, but when mastered, it will give you a better sound than just mono. For example; If you are amping your drums, they should always be panned in the middle. That is, unless you are going for individual snare separation. If your lead guitar stands to the left of the main vocalist, then the guitar should be panned slight left. Rhythm guitar should be in the middle. ETC. Remember, in the end, it all comes down to the sound you are trying to attain. So as the sound mixer, the ball is in your court. ^^ Good luck, and hope this helps.
Dec 09, 2015 | Mackie ProFX16 Pro 16 Ch. 4 Bus Mixer With...
Have a fender squier 4 and wondering if you plug one side can you get full mano output?
What do you mean by "Plug one side"? Your guitar is plug into the channel with a mono signal long as you're panned to center on your channel strip, you would have full mono sound sound equally from both speakers. Usually you would be running your board in mono anyway.
Aug 17, 2012 | Fender Squier 4-channel Travel PA...
Some DVD's sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it?
" Some DVD\'s sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it? "
I wrote a short article for someone who had a similar problem a few days ago.
I will edit it for you so that it fits. Here it is.
Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO (or MIXED ) Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo(or MIXED) then the dialog will be sent to the CENTER channel output. If you have no center channel speaker you will not hear it. Thus no dialog.
NOTE: In your case for the TV that is mono, here is the solution.
1 Connect a stereo pair of RCA cables (red and white "male" connectors at each end) to the Mixed or Stereo Output of the DVD player (NOT ANY SURROUND OUTPUTS).
2 Purchase an RCA type "Y" connector that has 2 female to a single male connectors on it. Walmart about 3 dollars.
3 Plug the single male plug of the Y connector into the back of the TV set's single mono audio input.
4 Connect the stereo RCA pair from the MIXED output of the DVD player into the Y connector that is now on the back of yourTV.
5 Run your yellow Video output from the DVD into the Back of the Set's yellow input.
That should do it. The sound should be clear and correct with dialog, effects and music.
Hope this helps,
Jan 27, 2011 | Audio Players & Recorders
My fender hot rod deluxe is distorting in clean channel when I push the volume past 2
Realize that the number on the volume control is only relative... it means nothing regarding what the amp can produce. With a high level output guitar you can easily drive the amp into distortion at very low volume control level settings... what counts is the actual output sound volume and specifically the voltage output going to the speaker. Once the amp reaches saturation, any further input just pushes it into distortion or "flat topping".
An oscilloscope on the output will quickly show when amp starts to flat top.
Jan 17, 2011 | Fender Hot Rod Deluxe Guitar Combo...
We are having problems with a PMP5000 board. We have the switch setting on Mon1/Mono. We can get sound out of the monitor output, but the mono output is almost silent. Do you have suggestions for...
Do you mean the SPEAKER mono output or the top mounted 1/4 inch jacks?
The A side power amp is used to drive monitor speakers and the B side the mains.
All other connnections of speakers require amplifier OR powered/active speakers.
Aug 20, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Onkyo tx-sr601 bi wire with zone 2
The idea behind bi-wiring speakers is to get the highest quality of sound by getting the sound from two separate sources doing separate jobs. Lower frequencies are harder for an amplifier to produce than higher frequencies. So it is common to give these frequencies to two different amplifiers so each can produce the highest quality of sound. By removing the low end from the top end amplifier, it provides the top end amp more headroom thus reducing the chances of clipping. Clipping can easily be heard from the tweeters destoying not only the sound but your speakers as well. It is common practice in pro and car audio to use separate amps for subbass, low, mid and high; four amps working together to their corresponding drivers (more or less depending on the system and type of audio being produced).
In your case, getting the two different sources from basically the same amp (power supply), would not accomplish the full intent of bi-wiring; it would just make more wiring for the same end result. However still a good thought on your end. Onkyo receivers are great because of their beefy power supplies. Not very many other brands have such strong power supplies. Denon's are close but not equal.
Feb 14, 2010 | Onkyo TX-SR601 Receiver
Sound only from left front and right front speakers possibly my projection screen tv is only 2.1 channel does this mean i cannot have surround
surround receivers are supposed to be able to turn a stereo signal into a surround signal.  if the surround unit is producing just a stereo sound, then the tv is most likely outputting in mono, and not stereo; or there is no surround sound to decode..
Dec 27, 2009 | Coby DVD-937 5.1 Channel DVD...
I turned my car on and when the amp turns on one speaker pushes out and the other pushes in and stay like that and dont produce any sound. i checked the wires and fuses and everything is correct but i cant...
Hello mikhail_1994,
I'm assuming that the amp was installed and was working properly.
It sounds like the output is shorted. The CH450 may be operated as a 2-channel amp or both channels can be bridged for mono powering subs at an impedance of 4ohms or more.
I'd test the sub voice coils and then test each channel of the amp separately.
Hope this helps.
Jul 20, 2009 | Boss CHAOS CH450 Car Audio Amplifier
Why aren't my games playing on the nintendo fc twin?
The FC Twin connects through an RCA connector, and can be hooked into a surround sound system. When using stereo and surround output from these systems, NES sounds and music may seem very different from their typical mono output. Using output modes that properly generate mono sound, either through a single center speaker or cloned to multiple speakers, the sound output sounds mostly identical to the original NES. The FC Twin does not produce some sounds faithfully, even with mono output; sound effects in the Super Mario Bros. series games will for example immediately seem different. Nevertheless, some later models of the console produce NES sound much more faithfully than units made closer to launch. Recent models produce sound with complete fidelity.
all this can be found here
Jan 18, 2009 | Nintendo FC TWIN Console
Very very low sound/output
Helle there!
1) check your setting for sound to (2 way speakers)
2) Setting for Volume in control panel.
3) connector may be you need a little expantion from radio shack gold ext.
4) be sure you got sound from headphones !! **
Go it!
Jul 31, 2008 | Philips SBP1100/37 Portable Speaker System...
120 people viewed this question
Top Sherwood Audio Players & Recorders Experts
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
