Question about SanDisk Sansa e250 MP3 Player
My sansa mp3 player stopped working after i charged it for eight
I was walking with it and it just turned off. i put it on the charger and nothing happened
  • 8,596 Answers
Make sure the hold/lock switch wasn't accidentally engaged.
If not:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 14, 2009
I Was Just Listening To My Mp3 Player, Then The Song Stopped, And Froze, So I Turned the Switch Off, And Now It Wont Turn On. I Tried The Reset Button But That Didn't Work Either. My Mp3 Is One Of Those...
Leave it on charge for at least four hours.
See if it works.
If it has charged from that port on your computer before the port should be ok.
You could try a different port if you have one.
If no luck, try a different charging cable or charger if you have one.
Charging is discussed on page 7 of the manual.
www.sandisk.com/Assets/File/pdf/retail/Sansa_e200_UserManual.pdf
If it is only a month old, it may be under warranty.
Ask where you got it from, or contact Sandisk.
The page for the Sansa is here www.sandisk.com/products/sansa-music-and-video-players
Feb 01, 2011 | SanDisk Sansa e250 MP3 Player
My sansa fuze will not charge
Download the latest drivers for it first. Then turn on, then connect via usb, then go to my computer and you should see your device in the drive folder
Sep 02, 2009 | SanDisk Sansa Fuze MP3 Player
Mp3 player shows that battery is dead even though its charged and the screen only works if i hold the on off switch the whole time
try inserting the charger to a different socket until it works. if not you might be having problem with the charger. not the mp3 player and if you already triedto change the charger you might be having problem with the battery of your mp3 player ok send me a message for more concerns.
May 04, 2009 | SanDisk Sansa m240 MP3 Player
How to charge my sansa mp 3 player
it doesnt matter if the mp3 is on or off if its off the mp3 turns on when you connect it to the computer or the wall charger then starts to charge if its on it just starts to charge
you should be able to see the little battery charging
Nov 12, 2008 | SanDisk Sansa E280 MP3 Player
My sansa mp3 player wot turn on
Actually there's none so think about buying a new charger and if it's not working then re-write to me so that I can help you more.
Sep 18, 2008 | SanDisk Sansa Clip MP3 Player
Sansa won't turn on after using an ipod "road trip" fm transmitter
Kinda the same thing happened to me. I tried to plug my sansa into my friends iHome and it blew out one of his speakers and screwed up my sansa, which was an e270.
Aug 28, 2008 | SanDisk Sansa e200 MP3 Player
Sansa E250 won't turn on after trying to plug it into an an ipod docking station my sansa mp3 player wont turn on or off the only way i can get it on is to plug it in to charge. and i cant take it to work...
my sansa e250 wont turn on only when i plug it into the charger...and when i try to turn it on without plugging it into the charger it says battery is low and turns off..when actually the battery is full...?
Jun 27, 2008 | SanDisk Sansa c240 MP3 Player
Problems with my insignia mp3 player
A Possible solution is to charger it all the way up 'til it's full, and then try turning it on. If that doesn't work, you may have to call sansa, and/or take out the battery and put it back in. This requires a special screwdriver.
Mar 14, 2008 | SanDisk Sansa e250 MP3 Player
Need the sansa c250 driver; won't charge from xp
this player really sucks ... and believe ... i love sandisk players... my solution for this was the following:
i ve got a wall charger (for itself it almost did nothing)
i put my player to dial and FM station (like i was listenning to a radio)
waited some seconds and connected my charger.
it appears that the player freezes but after 2 to 4 hours it get full charged.
before that i tried everything and nothig was solving the problem.
Mar 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
How to charge my mp3
make sure the power IS ON , before you put the usb cord in..that is the only way to charge it,,
Nov 27, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
