Question about Kenmore 23822 Top Load Washer
How do I get to the lid switch to replace it?
Tick, tick, tick and won't advance to rinse cycle. Lid strike is intact and mounting screws are snug. Mod 23832100
  • jjse64332 Feb 11, 2009
    I have a kenmoore 70 series model# 110.24712300 timer stops near end of cycle wont drain out and spin, makes clicking noise from possibly timmer.Strike pin present and screws are tight.
  • 333 Answers
It sound like you need a new timer which can be purchase at an appliance parts store. I hope this helps. Don't forget to rate my answer.
Posted on Feb 06, 2009
Washing machine stopped working during middle of rinse cycle. Would not drain or go into spin cycle.
I would recommend checking your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of a replacement is $25 to $35.
NOTE: Pounding on the lid or storing heavy items on the lid can contribute to premature failure of the lid switch.
If you have questions, please let me know. I hope this helps you.
Aug 22, 2009 | Washing Machines
Washer will not change cycles
If you have questions, please post back and let me know. I hope you find this information helpful.
Aug 20, 2009 | Washing Machines
Washer wont drain or go into rinse cycle
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions, please let me know. I hope this helps you.
Aug 12, 2009 | Kenmore 24902 Top Load Washer
Machine fills and aggitates just fine, then at the end of the wash cycle just stops. It won't drain, rinse, or spin. The timer stops advancing too, it just hangs at the end of the wash cycle. Manually...
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If you still have questions, please let me know. I hope this helps you.
Jul 29, 2009 | Kenmore 24032\24036 Top Load Washer
The washer does not go through the entire cycle..it stops at the rinse cycle
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you have questions, or my advice does not match your symptoms, please let me know. I hope this helps you.
Jul 11, 2009 | Washing Machines
Machine stoped at the begining of Rinse Cycle
Jul 08, 2009 | Washing Machines
Kenmore 90 Series washer wont advance past wash cycle.
I hope this helps you. Let me know if you have any questions.
Jul 03, 2009 | Washing Machines
UZltimate care II washer pauses for a long time between cycles
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills with water, does agitation and then it stops. If I move the knob to get it to go into a spin cycle so the water drains out, I hear a ticking noise at the knob like its trying to do something.
a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
Jun 27, 2009 | Washing Machines
Won't drain and go into rinse cycle
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured.
I can also provide information on how to replace a lid switch and give advice on where to purchase a replacement (if needed).
Feb 05, 2009 | Kenmore 23822 Top Load Washer
Kenmore 23822 Top Load Washer Logo
83 people viewed this question
Sal De
fordexpert
Robert Rankin
