Question about GTCO Roll-Up Digitizer, 30/36" (RU3036)
Wont recognize gtco digitizer on start up
I have an older roll up II digitizer with quick ruler. I was working on a project and the quick ruler screen showed self test and then showed digitizer not found. Any ideas
I have a Roll Up II digitiser with Quik Ruler when starting up, after self run test has passed it says: Press switch to relocate Menu, and it gives just a few seconds to do so, If i dont select anything it says: select menu. And then the yellow button on the 4point cursor doesnt select anything, neither does it beep when a selection is made.
BUT when starting up, if i select "relocate" on the menu in time, it asks to select left point, i do, it still doesnt beep but then says select right point after which it says: BAD REF POINT. I've tried using a new cursor, even a new quik ruler menu and tried moving the quick ruler menu around on the mat, but no Progress, the problem remains. PLEASE Help.
Posted on Aug 13, 2010
  • 49 Answers
First reset digitizer and make sure you hear four beeps and only four beeps.
Check the cables from the Quikruler to the interface module, make sure they are in good condition, no cuts, breaks missing pins on connector.
Check cables from interface module to digitizer. A good way to check for an intermittent problem is to bend the cable at different points and check the display on the Quikruler to see if has reset.
Select S01 on the superset code with your stylus or cursor. You get get four sucess tones (beeps).
If none of this works check the firmware version on the digitizer, some J2.0 firmware may become corrupted. When the firmware becomes corrupted, you will hear three(3) medium tones on power-up.
If this is happening it will have to be serviced by GTCO.
Posted on May 15, 2009
4 Suggested Answers
SOURCE: The GTCO digitizer roll up board was folded and now has a crease.
No, the lines in the Roll-Up are probably broken.
If you send it to GTC for repair, they should give you a discount on a new one.
Posted on Nov 27, 2010
SOURCE: I HAVE AN OLDER MODEL
You can try the Tech Support section at GTCO.COM or vtablet.com,on vtablet the drivers aren't free and will have to be purchased.
SOURCE: GTCO Roll-Up Digitizer... lines appear wavy and jagged
The GTCO ROll-Up is not a high accuracy tablet,it is made for general use by Estimators.
Normal accuracy is somewhere between 15 and 22 mil.
Are there any breaks in the line,this would indicate an open on the grid.
Are you using a Tabletworks driver? Check the options and make sure the correct size tablet is in the driver.
How to set up mouse on paydirt software, currently working in reverse
This could be a problem in Paydirt or the setup of the digitizer.
The Roll-Up II and Roll-Up III digitizer would allow you to change the orientation from one side to another,check this first.
The 0,0 point should be at the left hand side of the Digitizer where the metal housing and connections are.
There is a selection on the menu to change this,it looks like a double-headed arrow.
Sep 20, 2011 | GTCO Corded 16 Button Cursor with 3 meter...
Dell M6500 w Eports Dock setup rollup Serial Dig. Tablet Works Can not find (10.09 ver)
The GTCO drivers only recognize Com ports 1 and 2, if you are using a serial port for communications.
If you are using the USB driver for Wintab, the drivers may not recognize the E-Ports.
I would try the USB driver and cable,(CAUTION) the RUD III,gets its power from the USB cable,so don't plug in a power supply and the USB cable.
Only use the USB cable when using the 10.9 drivers.
Jan 11, 2011 | GTCO Roll-Up III Digitizer
I HAVE AN OLDER MODEL GTCO ROLLUP II DIGITIZER (3036R), BUT CANNOT LOCATE DRIVER DISK(S)---- WHAT IS THE BEST WAY TO OBTAIN A DISK? B.C.
Aug 29, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
I have a Roll Up II digitiser with Quik Ruler when starting up, after self run test has passed it says: Press switch to relocate Menu, and it gives just a few seconds to do so, If i dont select anything it...
You may have an open line in the grid of your Roll-Up and the Quikruler can't find a good point.
Turn on your RUD II and Quikruler and let it go through the sequence and place the cursor on the RUD.
There should be numbers displayed on the QR, if you take the cursor and go from the left part of the RUD to the right and see any of the numbers disappear, than you have on open in the RUD.
Call GTCO Tech Support and ask for an RMA if you want it repaired.
Aug 13, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
I have the stand-alone system with the LCD screen,
These original Roll-Up I Digitizers didn't use a power supply,all of the power came through the Com port connection.
The Roll-Up II used a 9 volt center positive power adapter.
May 14, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Apr 30, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Jan 29, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Looking for a manual for a 3648 III roll up
Go to www.gtco.com, select Tech Support/Large format Digitizers,then select GTCO Brand on the bottom of the screen, then select documentation and a PDF file can be downloaded.
Dec 17, 2009 | GTCO Roll-Up III Digitizer Graphic Tablet
Calcomp GTCO Roll upDigitizer
Go to the search on your computer and find your tabletworks. Open tablet works and go to mapping. Click pick. Locate your mouse pad on the digitzer pad. Click Apply. This worked for me.
Mar 29, 2009 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Using Calcomp 6 drawing board in corel draw and signwizard 4.1
I don't know about Signwizard but if Corel Draw is the problem, this might help. Double click on the ruler or...Go to tools and open the Options dialogue box. Click Document then click Guidelines then Rulers. The right panel should show a button the says Edit Scale. Click that. Make a note of what's there before you change anything.
You can calibrate the rulers to real-world distance too.
1. Click Tools Options.
2. In the Toolbox list of categories, double-click Toolbox, and click Zoom, hand tool.
3. Click Calibrate rulers.
4. Place a clear plastic ruler under the on-screen horizontal ruler.
5. Click the up or down arrows on the Horizontal box to match one unit of measurement on the on-screen ruler with one unit of measurement on the actual ruler.
6. Place the ruler beside the on-screen vertical ruler.
7. Click the up or down arrows on the Vertical box to match one unit of measurement on the on-screen ruler with one unit of measurement on the actual ruler.
Jan 07, 2009 | GTCO Calcomp 44"x60" SuperL III Digitizer...
Computers & Internet Logo
252 people viewed this question
Top GTCO Computers & Internet Experts
William F. Bryant Jr
Level 1 Expert
Ciricuario Dh
Level 1 Expert
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
