Question about HP Compaq ProLiant ML350 G5 Server
How to set server auto boot-up after power is back on the UPS
Hello. I (my company) have (-s) ''HP ML350 G5'' server which gets power from ''Mustek PowerMust 1400 USB'' and also is connected to it via USB. The problem is that I can set WinPower (software to control UPS parameters) to shut down or even hibernate server if the power-cut occures, but can not find where to set to load system when the power is back on the line. Should I use another specific software? Server uses Windows Server 2003.
Thanks
  • shuruoja Feb 10, 2009
    Downloaded from your link. Ran setup.exe. Got the message "This is not a supported server. Server Administrator software can only be installed on supported servers"
Hi, I have this on my server and it gives me options on for the server to reboot if there is a system problem or unexpected shut-down, this may help and maybe worth a try it works fine with windows server 2003.
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R108443&SystemID=PWE_PNT_P3C_2450&servicetag=&os=WNT5&osl=en&deviceid=2331&devlib=0&typecnt=0&vercnt=19&catid=-1&impid=-1&formatcnt=2&libid=36&fileid=143370
Posted on Feb 08, 2009
My HP ProLiant ML350 G5 failed to boot to Windows. After showing Windows 2003 Server, blank screen comes up
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Jan 05, 2011 | HP Compaq ProLiant ML350 G5 Server
HP ML350 G5 can't auto bootup after shutdown
It's divide and conquer time! First let's see if it's UPS or server related.
Try any, or all, of these Wake-On-LAN utilties to see if the server responds:
http://www.depicus.com/wake-on-lan/wake-on-lan-gui.aspx
http://www.matcode.com/wol.htm
http://www.solarwinds.com/products/freetools/wake_on_lan.aspx
If it does, then there is a problem with the UPS that needs further invesigation.
If it does not, read this article from APC:
http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_sid=eIzqf7Ti&p_accessibility=0&p_lva=215&p_li=&p_faqid=2929&p_created=1057853424&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9OCZwX3Byb2RzPTQ1MSZwX2NhdHM9JnBfcHY9MS40NTEmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9mbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13YWtlIG9uIGxhbg**&p_search_text=wake+on+lan
Also, if you are using a switch/router to connect the UPS to the LAN, make sure your network devices are configured to allow WOL.
Jun 19, 2009 | HP Compaq ProLiant ML350 G5 Server
HP SERVER PROBLEM
You should be using a 110 voltage cable if you are in the USA.
Jun 14, 2009 | HP ProLiant ML350 G5 Server
Connect HP Proliant ML350 Server.
Please verify if your server power specs support 110 or 220 V. If you are in the US, eventhough you might have connected a 220V cable the line voltage can be 110.
Check with your power company if they can provide you the necessary wattage of the server.(Specs are printed on the power supply. you can read it from HP web also)
Once you are sure that, connect both power suppllies and try booting.
If the error still occurs, it can be a power supply failure or some other hardware failure.
Regs,
Jun 14, 2009 | HP Compaq ProLiant ML350 G3 Server
Hp proliant ml350 g5 vga drivers for windows 2000 professional
Download the latest Proliant Support Pack from HP's web site. This will update the drivers for everything on the server at once.
Just go to hp.com and click the link for "Support & Drivers" at the top, then click the radio button to download drivers and enter ML350 into the text box. Select the G5 from the list and then select your OS. The PSP will be near the bottom of the page. The display driver will be close to the top if you just want to update it.
Apr 08, 2009 | HP ProLiant ML350 G5 Server
HP Proliant ML350 G5 wont boot ,just spining.
The G5 Series is fairly new, if you're within warranty, call 1800-okCompaq.
Could be a bad cable, a bad monitor, or bad computer hardware. Any display at all or any beep codes?
On the back, the ml350 G5 will likely have an additional Network interface jack-- this may be labeled ILO. The ILO network connect allows you to use another PC on the same network to access this system (like a remote control via VNC or RDP) even if it won't power up--literally. Inside the ILO page, (you'll need the IP address of the ILO, the default account is administrator, and the default password is listed ona paper tag attached in the rear or on a sticker. If you can get into ILO via web browser: https://ipddress of ilo, you can check the Integrated log, which can shed some light on any failures.
Mar 19, 2009 | HP Compaq ProLiant ML350 G5 Server
HP Compaq ProLiant ML350 G5 Server Logo
2,025 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
