Question about Cannon Cameras
Getting memory card error
Is this a bad card or something else
  • grady05 Feb 06, 2009
    I tried to format, but it shuts down and i get a e50 on the screen
    no data protection on the card, my guess now is the card is bad
  • 4,806 Answers
Hi there
Format the card, that should do the trick.
Thanks for using Fixya!!!
Posted on Feb 06, 2009
  • Lee Hodgson
    Lee Hodgson Feb 06, 2009
    ok take the card out and make sure the data protection lock is swithched off, then try format again
  • Lee Hodgson
    Hi again
    Yes the card is probably damaged.
    Kind regards
I am getting memory card error with my power shot A 620?
Memory cards do go bad, and some are even defective. What is the error you're getting? If it's a "read-only" error, memory cards have a switch on the side for protection of the contents. Switch that.
May 14, 2015 | Cameras
The message says memory card error....it is a new memory card
Try formatting the card- in most cameras there's a menu option under tools or system or something.
If the camera still can't use the card, try the card in something else (like a computer memory card reader or an mp3 player with a memory card slot). If it always has errors it's probably defective
Jan 15, 2011 | Cameras
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
When booting the screen says no signal and the it begins beeping intermedately
I think the graphics card has become unseated as the PC does not need a monitor to start up so there would be no beeps; Here is a list of beep codes with there meanings.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Apr 19, 2010 | Gateway Profile 5.5 PC Desktop
Canan 350D with CF error, says no image on screen. How do I fix this?
The memory card could be bad, try formatting the memory card, or the camera could be damaged. Look inside the memory card door, take out the memory card and look at the little pins in the camera that the memory card connects to. If any are bent or missing then the camera will need a major repair to be fixed. This is something for Canon or qualified technician to fix.
Nov 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Memory card reader
Try format the card using FAT (not FAT32 or NTFS).
May 29, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Cannon a510 memory card error
Yes, Don't panic please.
Simply, just take memory card outside and attach it to your laptop or PC. FORMAT that memory card using FAT32 and you will get it working again.
May 28, 2009 | Canon PowerShot A510 Digital Camera
Regarding Memory Parity check
this error is usually associated with bad memory cards......how much amount of memory are you using.....try reseating the memory cards(ram)....if you still get the error msg....try starting the system with jst 1 memory (if thr are 2 memory cards installd) & thn swap it with the other one......
Jul 18, 2008 | Lenovo ThinkPad T61 Notebook
D-380 smartmedia card formatting
There is something alled the CIS header on Smartmedia cards. If that is missing or damaged, any compliant Smartmedia device will not let you use the card. Many card readers are not Compliant and thus ignore the CIS block.
It is advisable to not try and "recycle" cards with a damaged CIS block by using them in a non complying card reader because of one of the reasons why the CIS block is there is to ensure something called the bad block table is present on the card as well. The bad block table maps the locations of bad memory cells and prevents writing to them so the card will apear 100% good. All cards have some bad cells from the factory even. Most likely the bad block table will be missing as well and your non complant card reader will end up writing over bad memory cells which will cause future read errors and data loss.
You would need access to a compliant Smartmdia reader that is compatible with the SMPREP (or similar) formatting utility to fix problem smartmedia cards. SMPREP fixes the CIS block and scans the entire card for bad memory cells and updates the bad block table.
Mar 13, 2008 | Olympus Camedia D-380 Digital Camera
Cameras Logo
23 people viewed this question
Top Cannon Cameras Experts
Pavel Pranovich
Pavel Pranovich
bhargav
Are you a Cannon Camera Expert? Answer questions, earn points and help others
