I get kicked due to high ping what should i do?
When choosing a server try to sort the list by ping rate and go with the lowest ping you can that is offering the map and amount of players you are looking for. If you frequently get disconnected or see connection_error on your screen while playing it could be a problem with your actual internet connection dropping packets. To test that you will need to ping a well known server like google or microsoft and see what ping times you get and if any packets are lost. This can by done by clicking start -> run and typing cmd then pressing ok. In the dos box that pops up type ping -n 20 www.google.com and press enter. Significant packet loss and high ping times could mean your connection is saturated from other downloads/uploads, there is some bad cabling or network hardware somewhere, or your ISP is having some problems. If you are connected to a router or other network equipment and assuming you have a high speed connection try connecting directly to the modem provided to you and see if that helps. If the problem continues you will need to contact your internet provider for additional troubleshooting.
