Question about Hunter (25417) Ceiling Fan
FAN DOESN'T WORK
AFTER A POWER OUTAGE THE FAN NO LONGER WORKS. My sister admits the she has dropped the remote a few times however the pull string light still worked. After a recent power outage nothing is operational .
  • 25 Answers
Replace remote control with a new one maybe something happned inside the remote.
Posted on Apr 16, 2009
Casa Endeavor fan works, light does not. Installed new receiver and tested remote both are good. Took the light to a repair shop, light works there, just not once attached to fan in the ceiling.
If your fixture has pull chains in addition to remote control operation can get the remote control confused. Try experimenting to find a procedure that works and follow it consistently. Also, a power outage can disrupt the whole routine.
Mar 13, 2017 | Dryers
We just recently installed a harbor breeze ceiling fan w/light and remote. During a storm the lights just quit working. What can we do?
Power outages cause ceiling fans to suffer memory loss. The basic "cure" is to disconnect fan power at the source and, while waiting a few minutes, remove the remote battery and press all buttons to verify that none are stuck. Reinstall the battery and test operation. Other factors may affect restored operation such as using wall switches and pulling the chains. The simple brain in the fan canopy can't remember switch and/or pull chain settings at the instant of power loss.
Jul 24, 2016 | Dryers
My ceiling fan and light does not respond to remote control any more. How do I get them to reconnect again?
Try removing power at the source, waiting a few minutes, and restoring power. Power outages cause the receiver to develop amnesia. In addition, if you try to restore correct operation by pulling chains or flipping wall switches, the receiver loses its tiny electronic mind. You may even find that the problem corrects itself at random over time.
May 15, 2016 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Non responsive light or fan
Oh, that fan problem. Just for luck, remove the batteries from the remote and press all of the buttons to eliminate a stuck button as a possibility. Next, go to the source of fan power (breaker or fuse) and turn it off. Do not mess with any switches or pull chains. Turn on the fan power and try the remote. Make note of this procedure because you will have to repeat it whenever you have a power outage or you mess with the switches or pull chains trying to solve the problem
Apr 25, 2013 | Casa Vieja Probe Brushed Nickel Ceiling...
Is there a way to take remote controll off of a fan mine stoped working after kids pulled fan or light pull
My ceiling fan loses remote control every time there is a power outage. The first thing to do is turn off power to the fan at the circuit breaker. Take the battery out of the remote and push all the buttons to eliminate a stuck button as a possible cause. Reinstall the battery. Turn on power to the fan. Check operation. You may have to pull a chain to "reeducate" the remote but you should be back up and running soon.
Dec 31, 2012 | Hunter 52" Ceiling Fan With Light And...
Just purchased 2 Hunter Clarington fans. Made an exchange on one because it would not work at all. With the other one, the remote works only sporadically. I will try the other remote on the exchange that I...
Hi PJ
The range on those and the Hamptons is notoriously short. On some it can be measured in inches.
The pull strings had longer ranges so that's what we went with.
Mike
Aug 22, 2010 | Hunter 52" Ceiling Fan With Light And...
Remote lightswitch won't work.
This may be obvious but you may need to turn the light on with the string and leave it on. Then the remote should work. Sorry if this doens't work or is too simple.
Feb 28, 2010 | Oasis Hunter 54' Ceiling Fan
Fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Dec 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
If you haven't already done so, replace the remote's battery with a brand new one . Make sure the replacement battery is NEW AND UNUSED, AND WAS PURCHASED RECENTLY, SO IT IS FRESH. Make sure it is installed properly, making good electrical contact, and the proper polarity is observed. Was the remote dropped, sat on or stepped on? Was a liquid spilled on it? Did your pet chew on it? Are any of the buttons loose or stuck? If the remote seems ok, try removing 120 volt power from the fan by turning off the circuit breaker or fuse an your homes main electrical service box. Wait 30 seconds, then turn 120 volt power for the fan back on. This may reset the speed control in the fan unit. If it does not cure the problem, consult a professional electrician, or replace the fan, whichever is more cost-effective.
wait 30 seconds and turn 120
Jul 13, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Hunter (25417) Ceiling Fan Logo
552 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
