Question about Compaq Presario 5000 PC Desktop
Compaq Presario 5000 wont boot up
When switched on the monitor says "no signal" and the PC just emits a beep every 4 seconds. The green power light remains on. the only way to de power the unit is to switch off at mains.
I used to be able to get around this by turning off at mains and leaving for half an hour. Now this doesnt work.
  • 1,602 Answers
Check the connection for the monitor, screws tight in the connector, if vedio card is seated firmly if a card
4 beeps ram, system timer not operational
memory may of come loose, if it has two 2 stick of ram remove one and restart it if it start ,than turn off add other chip or remove working one put in other chip if it starts, than turn off and put all chip in and restart machine.
reset memory chips on board if chips can be added or removed for upgrade or down grading,
rod
if need more info please contact again
candymangandy
Posted on Feb 06, 2009
    President:
  • 1,902 Answers
Check the memory, remove and reseat the memory. If that does not work then try and replace the BIOS battery, again if that does not work then it is time for a new motherboard. Do the fans turn on?
When I attempt to boot the unit, no signal is sent to the monitor or keyboard, nor does the green light next to the power button turn on. The amber light does not, either. The fan will run at high power...
I had the same problem with my computer and the Compaq-HP techs told me to pull the ram out and then put it back in. They called it reseating the ram.
This fixed the problem i had. Try this and good luck.
Feb 14, 2011 | Compaq Presario S4020WM PC Desktop
Pc power light stays on and no signal compaq presario pc sr 5404f and port from the pc is loose
Make sure the video plug is secured into the back of your tower also if you have another monitor you could try that to make sure your monitor hasnt gone bad.
Jan 28, 2011 | Compaq Presario 5000 PC Desktop
Can't get computer to turn on (compaq presario 5000)
Either your Hard drive (hd) crashed or your hd cable or port is faulty. if your software is corrupt boot with a boot disk (assume you are using XP or Vista), press R on the blue options screen. you will be given a black dos prompt screen. Type in fixboot and type Y for an answer.
Oct 26, 2009 | Compaq Presario 5000 PC Desktop
Compaq presario 5000 desktop won't boot!
oh that means you have a power failure so you have to take it for a repair
Sep 24, 2009 | Compaq Presario 5000 PC Desktop
Tower powers up great,but monitor has no signal
1st if the monitor light is yello and as soon as u switch on the comp,or if the monitor goes to sleep even though u ave checked the connection wht u need to do is u need to reset the graphic card if u ave a add on card and then clean the slot check for any damage or moisture and then put it back and reboot.i m working for hp ave got lots of those cases
'2nd wht u can do is press space bar and slightly tap the power button of comp seeif tht helps.let me know wht happened and in detail
Aug 25, 2009 | Compaq Presario 5000 PC Desktop
Not booting, blinking light
4 blinks, 1 second apart is a power supply overload. Have the power supply replaced if you haven't added any additional hardware lately. But also make sure your hard drive isn't bad and pulling an overload of power. it's rare, but I have seem that happen on some western digital hard drives.
Jun 13, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 won't turn on
hi,
The machine is getting the power but no display.This seems a RAM or motherboard issue.
1.Press and release NUM Lock after turning on and if it is responding this is a RAM issue and if not then the mainboard issue but before all refix the RAM once.
Thank You.
May 30, 2009 | HP Compaq Presario SR1830NX PC Desktop
Red flashing lights, will not completely start up
Do you have a windows XP cd?
If so you can try booting from the cd and running recovery console.
from recovery console type chkdsk -r
This should repair any bad sectors on your drive, allowing the drive to boot
(this scan may take some time)
Jan 23, 2009 | Compaq Presario 5000 PC Desktop
No booting for compac presario
do you hear your power on self test beep? check your video card. the monitor has a light on it it should be green if its working. what color is it? check all of your video plugins. It sounds like its booting but without video who knows
Jan 02, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario 5000 startup problem
Firstly the keyboard does blink, but do you hear 2 beeps one then another a few seconds later, if not memory or graphics fault. Are you able to start in safe mode(press F8 when pc is booting up)when menu comes up highlight 'Start windows with last known good configuration' then press enter and it should re boot. The graphics card(if it's not onboard)may need to be removed and re seated, also the memory. Also check hard disk drive ide and power cable.
Jan 15, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
143 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
