Question about Linksys Rangeplus Wireless Pc Adapter
Linksys Rangeplus wireless adapter not connecting
I installed it properly and when I try to connect it to a wireless connection, it'll say that the signal is strong and is connected in the Linksys Wireless Monitor, but then Windows says that I have ''little to no connectivity.''
This has happened at my apartment and my parents' house. Before my computer was sent out and had the harddrive restored to factory conditions, the wireless card was working fine.
The Diagnostic says that it's the password, but it is the proper one, because the built-in wireless card connects just fine.
I tried putting in the password in different securities (WEP, WPA) but I know it's WEP and it's still not working.
I uninstalled the adapter and reinstalled it, but to no avail.
This is for the RangePlus Wireless Notebook Adaptor, Model No. WPC100
  • 2 more comments
  • twenora86 Feb 07, 2009
    I tried the cmd and for the wireless adapter the IP address does start with 169
  • twenora86 Feb 08, 2009
    I already posted that the password works with my internal wireless card. My password is all numbers. It's not the wrong password.
  • Ved Pradhan May 11, 2010
    hi...
    you are getting a 169 ip address which is not a correct ip address...may be the security key is wrong and that is the reason you are getting limited or no connectivity...
    delete the old wireless profile from the adapter and then try connecting to it and before you put the network key,check it once as it is case sensitive you can do that by checking in the router page.....
    vedhick
  • John LeFebvre May 11, 2010
    You have an internal wireless card too? Maybe that is causing a conflict?
    Normally limited connectivity means that it has not picked up an IP address. Click START - RUN and type CMD. Click OK or press enter and a black window will appear.
    Type IPCONFIG and press enter. Your wireless adapter should show and address starting 192.168... If it starts 169... then it can't get an address from your router.
    If this is the case, let me know and I can try to help as there are a couple of possible solutions.
    Scholar:
  • 54 Answers
Hmmm....
you are getting an incorrect ip address so what we need to do is to reconfigure the wireless profile,
open up the linksys utility and go to the tab that says profile,you will see the profile that you have configured earlier,
click on the profile and click on remove once the profile is removed ****,go to the tab that says site survery...
click on your network and then click on connect it will take you through a setup screen,then choose the security whether it is wep/wpa and down below choose the bit type if the security key has 10 characters then it is 64bit and if it is more than 10 characters then 128bit....donot put the passphare to generate a key,directly punch in the number..
****1 more step you can perform before creating a new profile is go to start,run in the box type in cmd and then open the black box then type in netsh winsock reset catalog and then hit enter it will tell you to restart the computer,restart the computer and then try creating a new profile...make sure the internal wireless card is disabled when you create a profile..
hope this works for you...
vedhick
Posted on Feb 09, 2009
    Novelist:
  • 155 Answers
One other thing - if your internal wireless card is picking up an address that may prevent the other one from doing so - see if you can disable the internal card.
The only thing I can think of that would actively stop a card getting an IP address even with the correct password is if you have MAC address filtering enabled on your router - go into the router config and see if you can find if this is enabled, and add the MAC address of the new card (you can get this by IPCONFIG /ALL from the CMD prompt again).
Can not connect to Verizon MiFi2200 wireless network
Yes the verizon tech informed you right that the ip address will be acquired by your wireless adapter automatically. However there are lots of reason that your adapter not able to connect wireless.
1. Make sure no firewall or antivirus is blocking your wireless connection to connect wirelessly.
2. Make sure you are entering the right password for the wireless network if your network is secured.
3. Make sure the wireless adapter driver installed properly.
4. You can also try to restart the DHCP services through which your computer will try to get the ip address. I am giving you the steps how to restart the DHCP service once again.
- Click on start
- Under start search or under run type in services.msc
- Search for DHCP client and right click on that and you can click on restart. It will restart your services.
5. Make sure other computer are able to connect wirelessly to identify whether there is a problem with the router or a wireless adapter.
6. Make sure the wireless channel on the router is correct sometime due to wireless channel your computer not connect.
I hope this will help to resolve your concern. Still if you face any problem let me know.
Thanks & Regards
Jazz
Jun 27, 2010 | Linksys Ultra RangePlus Dual-Band...
Linksys Wireless Adapter that will not find the internet
I think you might be using the Linksys utility.
you can switch over to windows utility if it is XP or VISTA.
that will resolve the problem.
make sure that it will be connected to the network and should have proper IP address
Click Here for more info about wireless network set up
Oct 12, 2009 | Linksys Ultra RangePlus Dual-Band...
Linksys WRT100 won't connect wirelessly
Has the adapter in the laptop been enabled?
Ryan Frame
Creative Energy Associates Technical Center
Sep 05, 2009 | Linksys RangePlus WRT100 Wireless Router
Won't install on computer
Make sure driver software is installed before ever connecting the wireless adapter. You may need to do a complete uninstall and start over. Or, your PC is not compatible with the adapter. More info would be needed.
May 01, 2009 | Computers & Internet
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Linksys Rangeplus works fine for short periods
improve your PC's cooling system and your wireless adapter will work fine. you can attach a USB cooling fan to do the trick.
Jan 25, 2009 | Linksys Rangeplus Wireless Pc Adapter
Internet connection shows good bars but can't connect to web
first, can you please tell me if what OS are you using?
: if its VISTA or XP, please remove the network profile in your laptop ...
then search again for the network ... by the way what router are you using ? if its linksys please update this thread so that i can assist you if there is a need to reconfigure.
goodluck
Nov 25, 2008 | Linksys WUSB100 Wireless Adapter
Linksys Rangeplus Wireless Pc Adapter  Logo
463 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
