Question about Panasonic PT-LB10VU Multimedia Projector
Projector lamp doesn't come on
I have Panasonic LCD PT LB10U projector. At first the lamp LED is green, then it flashes, then it turns red, and the red lamp LED comes on and flashes. The lamp itself does not come on.
I bought a new lamp, which didn't change the symptoms. Then I bought and installed a new ballast. The symptoms are the same.
I measured the resistance across both lamps, they both read open on the ohm meter. Does this indicate the new lamp is also bad? Or is it a gas lamp that only conducts when a high voltage is applied?
The controller seems to work. Is there anything else that would cause the lamp to not come on?
  • summjoanne Feb 06, 2009
    I got a solution tip to record the number of light flashes. Just don't know where to do it to get more info.
    Green light flashes 68 times, stops flashing a second, then flashes 68 more times, stops, then flashes 4, and the red lamp indicator light begins flashing indefinitely.
  • Panasonic Master
  • 19,396 Answers
If this is a mercury lamp, you cannot test it with a multimeter. If this instead is a filament lamp and has no continuity, then must be replaced.
All the other symptoms let think this is just a blown lamp.
Posted on Feb 07, 2009
    President:
  • 2,559 Answers
Here is a link to the SERVICE Manual in pdf format
Posted on Feb 06, 2009
    Sergeant:
  • 250 Answers
Its the problem of the board on which the lamp is seated.that needs to be checked with a meter.as due to any faulty component on the mini board its not letting the board to turn on.and it blinks continuisously .
  • 10,594 Answers
Please check Fans in projector as all are running?
Regarding lamp resistance, Ballast Lamp has gap in both electrodes and will show open with Multimemter test.
    Sergeant:
  • 326 Answers
You will have to reset the settings after installing the new lamp other wise it will not work just click this link and check out the instructions http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
for ballast http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Sharp projector pg-d3050 not getting on, only led turns green for a while and then turn red?
I had very similar problem with a Panasonic PT-LX22 LCD Projector, try changing the lamp, this worked for me.
Oct 08, 2013 | Sharp PGD3050W: PG-D3050W Multimedia...
Panasonic PT-AE700E projector light does not turn on, instead the fan runs on high for an infinite time until turned off
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 04, 2013 | Panasonic PT-AE700E Projector Lamp
As all the posts on here I have the same problem. My panasonic pt-lb10u turns on, green light flashes, fan comes on. Then the green light turns red and the red lamp indicator light comes on. No light emits...
If your projector won't fire up then you can't reset the lamp counter so that is not the problem.
The combination of LEDs you have given does not correspond to an error message. There should be two LEDs, one of which is the Lamp Indicator, and the other is the Temp Indicator.
It's possible that an overheating problem has caused this. Make sure the projector is in an area where the temprature is between 0 °C (32 °F) and 40 °C (104 °F) and the humidity is between 20% and 80% (with no condensation). It shopuld have unobstructed air flow around it.
Disconnect the power. Remove the lamp and place it aside. Clean the air filters, using a hoover, being careful not to damage the filter which is located on the underside at the front of the projector under a flap.
Carefully reinstall the lamp (when you say you replaced the lamp, did you buy a new PANASONIC lamp from a reputable source?) Try to fire up the projector. Note down any combination of LEDs if the projector doesn't work and post hem back here.
Feb 14, 2011 | Panasonic PT-LB10VU Multimedia Projector
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    I just replaced the lamp on a pt-lb10u projector and when i turn it on the green light comes on for about 3 seconds then turns to blinking red and the lamp indicator flashes.. Any suggestions?
    There is a safety switch that is probably not fully engaged. Check the lamp door for any protruding post or the sides for a small switch. If the lamp door is not fully closed, it will behave as if the lamp was defective. Check that first and update this with the results.
    Thanks,
    Dan
    Jun 24, 2010 | Televison & Video
    Just replaced bulb and Lamp red light still comes on when you plug in the Panasonic PT-LB1OU lcd projector. Screen display states: Replace Bulb
    Replace power board: ETXMM519MBGB
    Or replace transistor Q107 on this board with a typical pnp for switching power supllies,there's not a part number for it on the manual.
    Dec 15, 2009 | Panasonic PT-LB10U Multimedia Projector
    Nothing comes on except the green standby light on PT-AE900E.
    I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
    Jul 24, 2009 | Panasonic PT-AE900U Multimedia Projector
    PT-L735 U projectors. Green screen and stretched
    The green is the result of the blue device failing. Happens about 4000 hours or so. LCDs can't handle the heat. Check the scaling of the image of the second projector. 16x9 vs 4x3.
    good luck
    Jun 25, 2009 | Panasonic PT L735U Multimedia Projector
    PT-AE700U Lamp led flashes red
    Reset the lamp hours. Here is the manual on how to reset lamp time.
    http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
    Good Luck and Please Rate Fixya!
    Feb 28, 2009 | Panasonic PT-AE700U Multimedia Projector
    Open Questions:
    Panasonic PT-LB10VU Multimedia Projector Logo
    370 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
