Question about Texas Instruments TI-89 Calculator
My answer has an E in it and doesn't seem to be right
I just fixed my calculator so it converts fractions into decimals but i am having a different problem. The answer contains an E in it and idk if its because i was trying to fix the previous problem or what?
When the calculator answers for ex: 345E15 it just means 345 * 10^15 calculators use this notation because they dont have enough space to picture the result, or maybe wile you were changing the mode you put it in scientific or in engenier insted of in normal
Posted on Feb 15, 2009
How do I fix an err: data type when trying to convert 0.1i into a fraction?
Set the Real/Complex mode to COMPLEX. (rectangular coordinates). See the screen captures that follow.
Sep 11, 2014 | Texas Instruments TI-84 Plus Silver...
While using Casio fx-300ES , I am unable to get answers in decimals. For eg. 3/10...should give 0.3, but the answer is again displayed as 3/10. any way to solve this issue?
The calculator has two Input/Output modes: MathIO and LineIO.
LineIO is the old way of entering numbers in calculators and results are always displayed as decimal numbers. Some calculators have a fraction feature and would convert a fraction to a decimal number and back.
In MathIO you enter expressions as you would by hand or as you see them written in textbooks.
In this mode, results are by default displayed as fraction or fractions/ radicals.
To convert the fraction/radical to decimals you just press the [SD] key. If you press again you cycle through all the available display formats.
So you can (if you want) use the MathIO to manipulate expressions and convert only the last result to decimal. By the way, fractions and radicals are generally more accurate than their decimal representations.
If however seeing fractions and radicals is too painful, just set the LineIO as your default mode. To do so press [SHIFT][MODE] to open (SETUP), then select [2:LineIO]
Feb 17, 2011 | Casio fx-300ES Calculator
How do i convert fraction answers to decimals?
If result displayed is to be converted, press the S-D key. This will toggle display from decimal to fraction and from fraction to decimal.
To force a result to be in decimal format press SHIFT = instead of just =.
To configure calculator to display only decimals, press the SHIFT MODE key sequence to enter SETUP and seledct 2:LineIO.
Oct 14, 2010 | Casio fx-300ES Calculator
I can't get the answer to display in decimals only fractions.
For converting answers in decimal to fraction or fraction to decimal there is a S<->D key above delete key.If the answers is in fractional form press this key and it will be converted to decimal form.
Jun 04, 2010 | Casio FX-115ES Scientific Calculator
How do you change decimals to fractions on a casio
If you enter an improper fraction or a mixed fraction with the the [a b/c] key it will be displayed as a fraction. This result being displayed you can press the [F-D] key to convert the fraction to decimal. If you do nothing else and you press the [F-D] key again, the original fraction will be restored.
However, it seems that you cannot enter an arbitrary decimal number and convert it to a fraction. The [F-D] key seems to work one way : from a fraction to a decimal number. You will only recover a fraction if the original number was a fraction.
Jan 19, 2010 | Casio FX-9750GPlus Calculator
How to convert fraction to decimal
You can convert between Standard Form (with fractions and pi) or Decimal form by using the "S<->D" button. Use Mode 1 if you mostly prefer fraction answers and you can use the SD button to convert to decimal or use Mode 2 if you mostly prefer decimal answers and use the SD button to see the fraction.
I hope this helps and good luck!
Please remember to vote 51218db.jpg Thanks.
Oct 31, 2009 | Casio FX-115ES Scientific Calculator
Changing decimals to fractions
You can always convert a fraction to a decimal. The reverse may not always be possible. Look at the example on the screen capture.
You may be lucky and recover a fraction you have just converted into decimal format, but you cannot just write 0.333333333333 and expect the calculator to convert it to 1/3: The true fraction 1/3 has an infinite number of 3's after the decimal mark.
Jan 06, 2009 | Casio FX-260 Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
I think the F-D function only works one direction from fraction to decimal. Decimal to fraction is a non trivial calculation that can have multiple answers so doesn't lend itself to a calculator feature.
Jan 04, 2008 | Casio FX-115ES Scientific Calculator
Texas Instruments TI-89 Calculator Logo
97 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
