Question about Philips Magnavox 51MP392H Rear Projection Television
Phillip magnavox 52 rear projection
My tv has been showing shades of red in the picture for some time now but usually goes right back to the normal color but the other night it just would not go back to the right color.
Can some one please help me and tell me if this is something I can fix my self or do I need to take it somewhere?
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be phillip magnavox 52 rear projection - 2c07611.pnghis is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos arophillip magnavox 52 rear projection - 578ba6c.jpg
Picture of a set that needs the fluid changed.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 12, 2009
I have a 52 or 55 inch phillips magnavox ptv 805 rear projection tv but the color isnt right on it everything else works fine i can see the picture fine but its just the color what can i do
Thats a common problem caused by the CRT coolant needing replacement. The Phillips CRT coolant kit is available from www.tvrepairworld.com which contains the coolant and the CD with instructions.
Jun 30, 2011 | Televison & Video
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
My picture is now always a pink to red shade on my
unplug your TV look on the back for a three controls marked red / blue / green "screen" turn / tap on them; watch the screen when you find the "dirty" control clean it with "TV tuner cleaner spray"
Mar 20, 2010 | Hitachi 57UWX20B 57" Rear Projection...
The red lamp on my phillips is not lining up
Here is a link to the manual for this bad boy. http://www.fixya.com/support/p220239-philips_magnavox_51mp392h_rear/manual-28755/page-52. Page 52 has a listing that says "If the picture has red or blue fringes, you may need to adjust the convergence. See page *Q-7." Follow the instructions there.
Oct 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Phillips cineos 52 inch have sound but no picture
i have a 52 projection tv phillip and the pic is off you see three images on the bottom nice pic in the middle and on top a little off.so what is the problem
Jul 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
The color is bad
my rear projection Phillips TV Picture has a green tint.
Jan 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Troubles with phillips projection tv. It is showing about a 6 Inch blurring color at the bottom of the screen and blurred color streaks throughout the screen, what could be the problem?
you need the DPTV305 - Dptv345 Convergence repair kit available at the following link. Its listed under the convergence repair kits category, comes with all parts and step by step instructions with pictures so you can do the repair yourself.
Here is the link.
http://servicemanuals.vstore.ca/
Oct 03, 2008 | Philips Magnavox 51MP392H Rear Projection...
Picture problem
I had the same exact same problem. You can get a repair kit from this site. http:///www.magnavoxhelp.com
Aug 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
137 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
