Question about Epson LQ-590 Matrix Printer
When printing document, half prints.
Document stops moving and lines print over top each other.
  • Epson Master
  • 5,568 Answers
You didn't mention which paper feed you are using but I would guess tractor-feed Z-fold? If so, you may have a damaged sprocket drive.
If not, you need to remove the platen and check for paper scraps in the paper path and if you ever use the printer with labels, you may have some residue from the adhesive impeding paper movement.
Also check that you do not have the printhead positioned too close to the paper as this can cause drag that will cause paper to slip.
These printers are just about bullet-proof with very little maintenance.
Posted on Feb 06, 2009
Whenever i try to print anything my printer prints the first 5 lines or so and then just stops and moves on to the next page where it print the first 5 lines before giving up again.
What type of document are you trying to print(PDF, MS Word doc, etc)?
Is the printer connected via USB cable, Bluetooth?
First thing I would do is try printing a different document or even a different type of document.
If printing different documents results in the same problem then I would uninstall the current drivers, download the latest drivers from Canon, then install those drivers and try printing again.
Also, if the printer is connected to your computer via USB cable verify the cable has no exposed wiring or try a different USB cable.
Mar 12, 2011 | Canon MP610 Photo All-In-One Printer
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
The last line of my document only prints to top
Adjust the bottom margin to be smaller in your page setup.
Jan 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
Print half of full page
If the printer starts to print and stop in the middle check the eletricity of your place, this may have a variation. If the printer prints a half page and give you the paper, with no jam, check the cartridges and then the main board.
Aug 13, 2009 | Lexmark X5470 All-In-One InkJet Printer
Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Jul 19, 2009 | HP Office Equipment & Supplies
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
Ghosting on HP2015 Printer
Hi gpeirce:
Ghosting is the result of a worn fuser assembly. Try to print a half page by printing a document and then try to open the top while the paper is going under the toner cartridge. You have to listen to the paper moving through the paper path.You will see that the paper has print on it but not the hole document. This will tell you if the toner cartridge is bad or the fuser assembly.
Hope this helps
May 30, 2009 | HP LaserJet P2015dn Printer
Printing
try to do a system restore to a date when it was working ok, if still no go, then reinstall the printer driver.
Jan 30, 2008 | Dell 922 All-In-One InkJet Printer
Epson CX3650 Printing Only half a page
This may sound nutty, but I have an epson stylus cx3650, with the same INFURIATING problem. And I think I *may* have just fixed it. and its daft, and simple, but we all know how picky printers can be!
Okay, the paperfeed at the top, on the left hand side is a grey slide, (right in the printer) to hold the paper in place. USE IT to keep the paper straight, it seems, if the paper goes in straight, the whole page is printed. I don't know how or why but it worked for me! ^^ (and this is after the printer was stored in a cupboard for a year, because of this problem!)
Nov 08, 2007 | Office Equipment & Supplies
Epson LQ-590 Matrix Printer Logo
185 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
