Question about Kenmore 24032\24036 Top Load Washer
How do I get at the timer on a Kenmore washer Mod 110.23812100 to change it? I can"t get the back panel off ... removed all screws ..must be some trick involved
  • 4 Answers
There are two plastic covers you need to remove to get to the two screws that hold the console. while facing the machine, at the top right of the console lift up and toward you on the plastic cover. it pops off rather easy. then look at the bottom right of the console where the cover was, you should see a phillips head screw, remove it. then repeat for the left side. the console will slide toward you about a 1/4 of an inch. then lift up and tilt the console back. there are two plastic strips that act like hinges to let you lay the console over the back. Now look at the top of the washer cabinet and you will see a spring clip on the right and one on the left. they pop out with a screw driver. stick the screw driver in the slot in the cabinet near the end of the clip closest you. hold the screwdriver vertical and push the handle toward the back. the shank of the scrdvr will push back on the hump in the clip.
Posted on Feb 08, 2009
    Scholar:
  • 99 Answers
This is joyce
Try to take back off machine and you can get to it that way. their are some clamps that have to be removed on the side of the timer that hold it to the machine for vibration reasons. if this does not help please let me know.
thanks,
joyce
Posted on Feb 06, 2009
How to replace timer
I have a link to Sears parts direct. According to the diagram, there are screws in the back of the top panel. Remove the screws (1) and you can take the back cover off (4). Then remove the wires from the timer (13)that are plugged into it, and the agitation delay board (19). Then remove the knob and nut holding the timer in place. Pull out the timer and then do the reverse procedure. Here is the link to the diagram. http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11029832801/0582/0153200/K0905012/00002?blt=06&prst=0&shdMod=11029832801
May 13, 2014 | Televison & Video
How to change the timer on a kenmore 40042
By removing back plate of washer you should see the wiring to the timer and also the timer it self. By removing the button on the front of the timer you will see two screws which remove the timer.
Feb 11, 2011 | Kenmore Washing Machines
Is it difficult to replace the timer on a kenmore 22942 (Elite top loader)?
you should be able to remove your control panel end caps them remove the 2 screws holdind it on and then pull towards you just a little and flip the panel back it has plastic hinges on top so be careful not to break them , you can get right to the timer ,don.t forget to unplug unit!
Feb 15, 2010 | Kenmore 22942 Top Load Washer
How to access the timer on my kenmore 11026962502
((((top load washer machine )))
first UNPLUG THE WASHER FROM THE POWER OUTLET..!
On the headpanel looking at the knobs
you will see the side covers on the end of the head panel. depending on the model of course, the side covers pop out
lift the bottom of the cover slightly, then the top an pull to the outside
then use a philips screw driver to remove the two screws one on each side, then slightly move the headpanel towards the back , then raise it then up an you right in it
to remove the timer you will see some srews holding the timer from the back, and to remove the knob pop the time knob out an turn it clock counterwise an the knob will come off
just a comment am not sure why you chancing the timer on your washer, but iin case your washer washes an stops right at the spin cycle, and is fill w/water. is not the timer that is bad, check the lid switch may be broken!
good luck post some feedback!
Feb 01, 2010 | Kenmore Washing Machines
Kenmore 80 series wont run at all
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 29, 2009 | Kenmore 23822 Top Load Washer
Removing face panel on Kenmore clothes washer 417.40412700
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 09, 2009 | Kenmore Washing Machines
How do I gain access to change lid switch and water valves of kenmore washer #110.24712300
on the top of the washer, where the timer and adjustments for the washer are, the side decrative panels come off, after you remove them back out the screws and tilt the head unit up, you will see aset of wires atached to the case, unclip them, then you will see on each side, on top a brass colored "s" shaped clip connecting the case to the back panel, use a screwdriver(flathead) to remove them(place screwdriver down into clip and push the screwdriver head towards the back of the wash machine and they will pop out. now tilp the case towards you, and pull backwards...the lip switch is underneath the case.
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washing machine mod.# 11026842692
could be a broken 2nd rinse switch. contacts would not open up.
the noise could be coming from the gears inside the timer slipping.
if it is a kenmore, usually, it has these plastic cover on each side of the control panel. pry it slowly and lift it to exposed a screw that is holding the panel.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 110.92380200 washer lid switch replacement
You first have to remove the 2 phillip head screws on your face panel.There is one on each side located about 1 inch from the front corner.tThese 2 screws are holding down the entire front timer panel.Ok,now lift up & forward at the same time so you can swing back this timer panel and get it to balance back out of the way.Now, it becomes a little harder,locate the harness that your lid/spin switch is on by unscrewing the 2 screws on the spin switch.Pulling the bad switch away from your cabinet will expose the harness ,that way you will see where it is plugged in.After unplugging it your now ready to plug the new one in and just tuck in the harness in the cabinet.Flip the timer panel back down and screw it back down.Your done !!!
May 20, 2008 | Washing Machines
Kenmore Elite, Quiet Pak II Top Loading Washer
there should be 2 screw on the left and right side of the console. remove the screws and the console flips back so you can get to the timer. youll have to remove the knob and dial from timer too to get to the screws that hold the timer in place. if you dont have a local appliance parts store in your area then you can order the timer at sears.com and theyll ship it to your house
Nov 24, 2007 | Kenmore 15944 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
44 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
