Question about Pacific Image PrimeFilm 1800u Film Scanner (35 mm)
CyberView X - SF USER INTERFACE screeen does not pop up
On my PrimeFilm 1800u, the cyberview SF-interface screen appears for a split second, and then disappears; this prevents me from cropping the photos. I can only edit color, etc from the cyberview main menu.
Does anyone know how to resolve this?
  • Jacob Blackwood
    Jacob Blackwood May 11, 2010
    Is the interface screen another window that opens up?
4 Suggested Answers
  • 52 Answers
SOURCE: Failure to communicate with scanner (Primefilm 1800u)
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this article can helps you to make your computer faster..
Posted on Sep 03, 2009
  • 11800 Answers
SOURCE: I have a Mac OS
http://www.scanace.com/download/driver/CVXSF/113a/MAC/SF_ENG.dmg
This is the driver - copy/paste it in a blank browser address and a download window will appear - Save it then follow the very clearly explained steps from that page
1. Disconnect the scanner from the computer (if it is currently connected)
2. Once the file is downloaded you will have a VISE logo icon, Cyberview X double click on this to begin the installation follow the onscreen prompts
3. The password it needs is your Apple system password, if a previous driver was already installed you will be prompted to remove it, select OK, then when that has completed the new version will be installed automatically
To use these new drivers
Go to Mac HD-Applications-Cyberview X_SF- and click on Cyberview X (looks like a piece of film)
Once loaded you can click on this film icon in your dock and select to keep it there for easy program access in the future ; this is it's user manual,save it for further use
http://www.scanace.com/download/driver/CVXSF/PDF/CVXSF_E.pdf
Posted on Oct 18, 2010
willem52
  • 359 Answers
SOURCE: I have managed to install
You did not tell us what you installed... but the latest software you can find here.
It's also for Windows Vista and Windows 7.
Posted on Jul 23, 2011
Cyberview x for primefilm1800u windows vista
You post to a fix it site without even stating a problem? What the hell is wrong with you?!
May 28, 2014 | Pacific Image PrimeFilm 1800u Film Scanner...
This is a 6-year old scanner (brand new) and I would like to install on a pc with Windows 7
The drivers are available here: http://www.scanace.com/support/Cyb_X_SF.htm . The English version is here: http://download.scanace.com.tw/CyberView_X/CVXSF/PC/118c/SF_ENG.exe .
Turn off the scanner and disconnect the data cable. Make sure that any other scanners or all-in-one printers are off. Download the file from above and then run the file as administrator. If you are the administrator, double-click on it. Connect the scanner and turn it on when prompted. Then click Start > All Programs > Cyberview X to scan.
I hope this helps.
Mar 24, 2011 | Pacific Image PrimeFilm 1800u Film Scanner...
I have not used my PrimeFilm 1800i for quite a while and find that I probably need a driver on this computer. I used to use it but I am not sure which of my computers it ran on. What can I do to make...
You need to install a CyberView X scanner driver to use this scanner on Windows and Mac OS X.
On Mac OS X, you need to run VueScan with Rosetta, since CyberView X is a PowerPC program. To do this:
  1. Click on the VueScan icon while holding the Control key
  2. Choose 'Get Info'
  3. Check 'Open using Rosetta'
Aug 15, 2010 | Pacific Image PrimeFilm 1800i Flatbed...
Trying to use PrimeFilm 1800U scanner on my Dell PC (with Vista), but when running supplied Presto ImageFolio (Mr. Photo) CD, the following message appears: 'String MSG_OS was not found in string table'....
Uninstall Presto Mr Photo, image folio & Cyberview, all of which are not Vista compatible. Obtain new scanner drivers from http://www.scanace.com/en/download.php. Also, can use any image editor once scanning complete. Google provide free application called Picasa at www.picasa.google.com.
Sep 09, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
Aug 27, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
I have a pacific 1800u scanner but can't reinstall since my hard drive crashed can't find installation disc, is there a way around this please advise. email (archerjo@hotmail.co.uk). Regards
For downloading the driver to install your pacific 1800u scanner go to this link: www.opendrivers.com/driver/.../pacific-image-primefilm-1800u-scanner-driver-cyberview-x-sf-1.13a-mac-os-free-download.html
Aug 16, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
The software cannot communicate with the scanner (Prime Film 3600
I have a PrimeFilm 1800u. When I attempt to scan into a Roxio application, the program does not respond. The hardware and software are both installed. No problems scanning or communicating with this scanner before. Is there somethere there that has a soultionfor this problem ? Thanks
Mar 16, 2009 | Pacific Image PrimeFilm 3600u Film Scanner
Unreconizable image
Try updating your scanner driver/software to isolate the problem. If same issue still occurring after uninstalling/reinstall, then source of the problem may be a CCD/lamp failure or some sort of dust, lint, on CCD causing calibration failure.
Sep 03, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
Pacific Image PrimeFilm 1800u Film Scanner (35 mm) Logo
649 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
Willem.
Willem.
Greg Cann
Greg Cann
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
