Question about NorStar T7316E Corded Phone
I need to know how to take the security code off my phone
I don't want to have to type in a security code every time I listen to one of my messages. ebend@ptd.net.
  • 63 Answers
Program a speed dial key with your mailbox number, a pause then your security code.By pressing the speed dial key it will dial up your voicemail box and automatically dial your security code.
Posted on Feb 07, 2009
I FORGET MY SECURITY CODE FOR NOKIA 1661-2 TYPE RH-122.I NEED HELP TO UNLOCK MY PHONE
Please post your IMEI here so I can give you the code. Don't know your IMEI number, check my post here
Jun 09, 2011 | Nokia 1661 Cell Phone
I want to lock my Mobile Nokia 1616, How can I do that ? If I put any code It says code Error, I don't know what to do with that. Please Say me the steps to lock my Mobile with a code .. thank you
firstly if you buy it new so your default security code is 12345 and to change it go to settings security settings change access codes change security code . type the default security code and type your new security code (twice)
you can type security code until 10 numbers
May 23, 2011 | Nokia 1616 Cell Phone
I cant seem to be able to send any messages though i have credit. was thinking to restore the factory settings but apparently i dont know the security code?
ok listen.i was confused.u cannot send a message and u try to restore but u dont know the security code.of course u cant send message cause u dont know the securitycode.simple,try 1234 or 0000 if not.change simcard.and if not make it that for program in repair shop.they will delete ur code and no more code and u can send mesg.
Nov 12, 2010 | Nokia 1112 Cellular Phone
Lost security code toshiba dkt3010sd phone. Need to check messages
I can help you solve this dilemma, but I will need to know what type of Stratagy Voicemail you have to be 100% sure.
Here's a procedure that may work for ya, if it doesn't just let me know which VM you have and we'll get you setup.
Dial Voicemail (usually 100), when you hear the greeting press the * key. When it asks for your User ID, dial 999. When it asks for the security code, try 999 or 999997. Once logged in press 8 for system functions. After that, listen to the prompts and it should walk you the rest of the way through it.
May 18, 2009 | Toshiba DKT3010SD Corded Phone
I have an N70, Do you happen to know the Master Reset Code
The default security code for Nokia is 12345
IMEI: 357968007960658
Master code: 7176552371
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Jul 15, 2008 | Nokia N70 Cellular Phone
PLEASE HEEEEELLLPP
The default Security code for Nokia is 12345
IMEI: 358672010590572
Master code: 2501005436
Close all applications on your phone. (if you can)
Type in the security codes (anything) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Are you sure it’s the Master code you need. Which is the one that you want?
Jun 23, 2008 | Nokia 3110 Cellular Phone
W850i
IMEI: 352826018904245
Master code: 3036741103
Take your SIM card out first.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only. You type in the security codes (anything) until the phone request the Master code; when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
Apr 29, 2008 | Nokia N73 Cellular Phone
W859i
Security code problem
Master Reset Code
IMEI: 358647011866197
Master code: 4154001611
"Always remember you're unique, just like everyone else."
Apr 17, 2008 | Nokia 6300 Cellular Phone
NorStar T7316E Corded Phone Logo
374 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
