Question about Ruud UAMB Air Conditioner
What size is my ruud gas pack
The sticker plate on the side says the heat part is 97000 btu. I can't find where it says anything about the cooling size. The model is URGG-10e37jkr.......and the serial # is AYA4785...and here are some more numbers after the serial # A HA AF4492 9329...appreciate any help with this....
  • Ken Bledsoe May 11, 2010
    Can you get your model number off the condenser (the part outside) and give me the numbers?
  • 700 Answers
You have a 92' three ton unit in the mod # the 37 signifies 37000 btu, and the servial number states that it was made in the 44th week of 1992.
Posted on Feb 07, 2009
How many tons is a RUUD UAPM-060EZ
Ton rating is not used any longer. It is now called SEER and is completely different, You can convert BTU to either one and the spec on the machine is : 4 HP, 208-230V, 1 PH, 49,400 BTU, R410A
Dec 01, 2017 | Ruud Heating & Cooling
50BB16980 to know the ton of this unit
Hi, Need more data of your aircon. Please check also on name plate / sticker on your unit. There should be information of BTU/H, Kcal/H, watt of cooling etc. 1TONR = 12.000 btu/h. 1 watt cooling = 3.41 BTU /H. From that you can check exact data of your air conditioner ( i call it 'aircon') tonnage.
Regards, vote please, Jay
Jan 26, 2011 | Heating & Cooling
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Is a model py1pnb036090abaa Payne gas pack large enoug
3 ton cooling capacity 90,000 btu heat capacity. In Vermont it would be enough if the home was a 4 or 5 star home. Remember it is only 80% efficient so you will only net 72,000 btu output.
Mar 09, 2010 | Heating & Cooling
Wont heat a 1,500 sqft one story home..air is cold by time gets to far end of home..gas pack 3 years old
One thing you can do is slow the blower down, this
will give you greater temperature rise and heat evenly.
The length of the home is what is needed.
Its possible that you need to have dampers installed in your ductwork or you need a booster fan installed
on the ductwork that feeds that side of the house.
My guess is that you need 80,000 btu heat output
to come close to heat the house. Since ductwork is
sized for cooling you would need 36,000 Btu Cooling
output. More information is needed
Feb 14, 2010 | Ruud UAMB Air Conditioner
Ruud gas pack has stopped heating.
Could be a faulty thermostat, (referring to the furnace\heater. As far as the A.C., you must have a dual thermostat with a switch for A.C. and Heating. Is the thermostat digital or mercury bulb? As for the A.C. it sounds like it is going off on high discharge pressure. Is the cooling fan running that cools the condenser? It must be spinning freely or it may be starting and because it is partially seized, it will cut off with a high current draw. Anyways, the condenser must be clear of any debris, no shrubs around it. The compressor could be bad and trying to start but goes off on overload because it isn't starting. It's start capacitor could be bad and not giving it that extra boost on start up which is what a start capacitor does. Good luck.
May 31, 2009 | Ruud UAMB Air Conditioner
Capacitor unable to read what size
If it's the condenser fan motor cap then look at the label on the fan motor for the size usally 3/5 mfd.
If its the compressor run cap then check the top of the compressor or the info. plate/sticker on the unit for the size of the cap. Let me know if you have any other questions.
Phil
Apr 10, 2009 | Ruud UBHC Air Conditioner
Is it spark ignition or a glow coil? Sounds like the ignitor is busted. If it was a roll out switch the fan would stay on trying to cool off the switch.
Feb 24, 2009 | Ruud UAMB Air Conditioner
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
Ruud UAMB Air Conditioner Logo
604 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
