Question about Sharp AL 1631 Copier
Head unit wont scan
The head unit wont scan across the glass to make the copy? I have had this problem in the past and the head unit was in lock position but now it is not locked and still won't scan. Help??
  • 37 Answers
Clean the underside of the platen glass, be careful to remove the screws, also there is a plastic cover at the top of the platen under it there is a white correction plate clean this plate with cloth.
Posted on Mar 01, 2009
Issue with scanning documents to PDF however no issues with printing documents
from the sounds of this you have dirt or something on the scanning lenses. you need to check where the document you are scanning is loading it is carried across a lens that creates the image, if this is dirty you will get your symptoms coming out. if you lift the cover where the document is feed in you can clean this lens with some glass cleaner and a soft cloth. if all is printing ok you will waste ink by carrying out cleaning and alignment programs so save your ink and check the lenses for scanned doc. Hope this helps.Andy
Mar 11, 2015 | Office Equipment & Supplies
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
Equally spaced lines across page only on color copies
If not in the direction of the paper feed then in the direction of the scan head. Dirt on the scan head or bad scan head or scan head connection. Send it back.
Nov 15, 2013 | Konica Minolta Bizhub C284 Color Copier /...
How to solve scanner error 12 problem
Replace Scan head mechanism(while scanning or copying there is a part called scan head moves right to left with light fails to move due to mechanism breakage). For reaching this unit you need to remove flat bed glass. Pl see the snap shot for observation, its easily available in leading spares vendors in India.SCAN HEAD:
3_30_2012_9_11_30_pm.jpgSCAN HEAD MECHANISM
Mar 29, 2012 | HP LaserJet M1005 Printer
Why hp laserjet m1005 printer are scanner error 6?
Replace Scan head mechanism(while scanning or copying there is a part called scan head moves right to left with light fails to move due to mechanism breakage). For reaching this unit you need to remove flat bed glass. Pl see the snap shot for easy identification:SCAN HEAD:
Hp psc 1210 will print but not copy
Symtom that scan head might be faulty, remove four screws located at corners, take out flat glass unit, remove scan head, check any damages in driving mechanism, clean reading head, fix it back and check.. If no result replace scan head unit..
acsn head snap shot:
Feb 03, 2012 | HP PSC 1210 All-In-One InkJet Printer
LASERJET M1005 MFP) SCANNER ERROR 12 DISPLAY IN A SCREEN I CAN NOT SOLVE THIS PROBLEM NO SCANNING , NO PHOTO COPY IN MY PRINTER PLEASE HELP ME HOW TO SOLVE THIS
Scan head mechanism failed. Remove flat bed glass, take out scan head unit, verify any breakage in mechanism gear pinion,if found replace gear mechanism, if no breakage found replace scan head driving motor. You can see the scan head mechanism as snap shot..followed by how to alter the pinion..
For tech guys:How to alter the pinion.
1_4_2012_7_55_18_pm.jpg1_4_2012_7_55_47_pm.jpg1_4_2012_7_56_11_pm.jpg1_4_2012_7_56_49_pm.jpg1_4_2012_7_57_28_pm.jpgFollow the snapshots, be patience & do it. This is available part if anything goes wrong don't worry.. Best of luck....
Jan 04, 2012 | HP LaserJet M1005 Printer
When I copy using the auto feed, I get a line across my copies. The line can fade or be dark but has been present for a few months. Copies that are hand placed do not have the line. What can I do?
There is usually a little strip of glass to the left of the main glass bed where you would place paper by hand. This little strip is what the feeder passes the paper over to scan it while the scan head stays in place underneath it. Most likely there is some fuzz or dirt on this strip of glass or on the feeder where the paper passes.
Oct 18, 2010 | Ricoh Office Equipment & Supplies
When making copies using the ADF, vertical lines print out on the paper. Doesn't happen when paper put directly on the glass.
The ADF works by moving the paper past the scanhead, on glass works by moving scanhead past the paper.
When you are scanning with ADF, the scanhead is parked in a particular position, under the glass. Just at one extreme end. Open the unit to te point that you are able to clean the lint, debris, lollipop sticks from this area. That should be it, since works otherwise indicates a good scan head.
Nov 02, 2009 | Canon ImageClass MF5770 Laser Copier...
Where is the scan head locking switch
hi dear
Release the scan head locking switch.
The scan head locking switch is under the document glass.
If the switch is locked ( ), the machine will not operate. Unlock the switch
oke
cropp
Mar 19, 2008 | Sharp SHP AL1655CS Printer, Scanner,...
Sharp AL 1631 Copier Logo
65 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
