Question about Kenmore 24032\24036 Top Load Washer
Not agitating or spinning
It fills and drains, but will not agitate. When it gets to that cycle I can hear a grinding noise. Its sounds like metal on metal unless there's a slight echo in the machine.
  • 6,784 Answers
Hi there, im sensing a drive belt failure but, this could also be a Burned out motor as well. hope that helps ya and thanks for using fix ya:)
Posted on Feb 06, 2009
My Maytag PAV2200AWW Washing Machine makes a noise like grinding or metal-metal contact during the agitate cycle. How can I fix it?
The sounds of 'metal grinding/banging" begs the question of whether or not its even safe? If you hear that sound all the time or as you say ONLY during the agitation cycle suggests that you be able to service the tub/motor mounts in the underneath chass--which is a heavy-duty technician job. A Maytag technician has the tools you need. Or the obvious...get another one from a friend who is upgrading to a new washer and hands it down to you for a little change.
Dec 12, 2015 | Maytag Washing Machines
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Grinding noise while agitating.
possible foreign substance under agitator
Feb 26, 2009 | Admiral AAV7000A
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Make noise during wash cycle, has no agitator action and no spin during spin cycle/drain cycle
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Ron Lankford
Archaeology
Archaeology
reliableservice
