Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Canon mp730 paper jam.
Misplaed instruction book. this is a real paper jam. How do i get into the area & remove the paper.
  • Tessa Larson Mar 01, 2009
    Paper jammed and folded up accordian-style. Was able to pull out part of the paper but some paper must be left inside as it will not take another sheet of paper. I opened up the ink replacement area and can not see any paper. Can anyone help!?!
    Master:
  • 848 Answers
Hi
The manual is available in this site .....Follow the direction from it to access the paper path .....
http://www.fixya.com/support/p360581-canon_multipass_mp730_all_in_one_inkjet/manual-10204
Posted on Feb 06, 2009
Canon MP730 Paper feed is not working correctly.....keeps jamming and feeds the paper incorrectly
There are two feeders on this MP730. There is the sheet feeder on top and there is the paper feeder on the back. You can have problems with both.
The sheet feeder on top.
If the problem is things go through somewhat sideways, and if this is the problem, stuff some postit notes between the back grey thing and the feeder tray to eliminate this problem. Add or subtract to the wad to make it right.
If the problem is it does not grip the sheet, what I used to do is to help it through by one sheet at a time, painful. I got frustrated with this so for scanning, I have a Snap Scan 1500, which is faster and better.
The paper feeder.
A small piece of paper left in the paper infeed path can cause a major problem. You cannot have anything in the paper path that will skew the paper, so you must get any little bit of restriction out of there.
As the printer gets older, you will have to produce your own guides to prevent this skewing, as the guides on the printer do not do this well. I use clamps and wooden guides to keep things in line.
May 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
I don't know how to fax
The control panel LCD also provides menus to operate the copy and fax modes independently of a PC. One nice touch: the LCD displays small and large type on the same screen, allowing more information about a print job to show at one time. b.gif 21262659-2-200-dt2.gif
The flash card reader under the control panel means you don't need a PC to print photos.
The MP730, while easy to operate, lacks some of the advanced features you might find on separate printers or faxes. For example, the MP730 can't collate copy jobs. To make more than one collated copy of a multipage document, you have to place the document in the ADF several times. Nor can the MP730 sync fax numbers entered by hand or accessed from within the Windows Address Book (Canon doesn't provide its own fax/address-book software), so you may end up duplicating efforts. Nor does Canon's software create group dials from your address book on your PC or provide a cover sheet. Finally, the MP730 can't forward faxes to another number or hold a fax to send when nighttime low rates kick in, which other multifunctions do.
Still, the MP730 provides plenty of features we do like. Using the menus with the Photo Print mode, you can print a photo contact sheet, pick individual images to print, and set up the printer to copy or print onto high-quality glossy paper. In the Copy mode, menus let you print two reduced originals side by side or print the same image on the same page several times (useful for business cards, name tags, and so on). The fax engine distinguishes voice from fax, sending voice calls to your phone or an answering machine and sending fax calls to the printer or to buffer memory so that you don't have to get a second phone line installed for your fax.
Installing the MP730 software is slow but idiot-proof: You just pop in the CD and follow instructions, which require restarting your PC several times. Canon bundles the MP730 with ScanSoft's OmniPage SE, a lite version of the best optical-character recognition software on the market, and NewSoft's Presto PageManager 6.0, one of the best document-management databases available.
The MultiPass MP730 won't replace top-of-the-line printers and scanners, but its print and scan speeds keep up with other multifunctions' as well as that of most as midrange ink-jet printers and scanners on the market today. In our tests, it printed ordinary text at 6.4 pages per minute and printed CNET's high-resolution test photo in 3.7 minutes. For comparison, the Lexmark X5150 (only $149 but without fax capability or automatic document feeder) prints text at a more common 5.2 pages per minute, and printed our test photo in about 2 minutes. Canon's MP730 scans a page of black in 9.4 seconds and a page of color in 20 seconds; that's seconds faster than the HP PSC 1210. And the Canon makes copies in 18.7 seconds; that's almost twice as fast the HP PSC 1210.
Unfortunately, the MP730 delivers a mixed bag on image quality. When printing, better paper has a big effect. When we printed text on ordinary paper, for instance, it looked grayish instead of black, and a gray shadow haunted the edges of letterforms, while on coated (not glossy) inkjet paper, text popped out in a solid black and looked much cleaner. Our color photo on ordinary paper looked very dotty, had rough transitions between shades, made a blob of detailed areas, printed lines with jagged edges, and mixed inappropriate colors; coated inkjet paper improved detail and let colors appear in the right hues, though much too saturated. And on top-quality glossy paper, textures, shading, and transitions suddenly looked right, and we saw sharp, clear detail.
Grayscale scans on the MP730 when compared with other scans seemed overexposed, losing paler shades of gray along with some detail, while color scans showed accurate colors and fairly good detail despite somewhat grainy textures.
Jan 27, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
Jammed cartridge error froCanon MultiPASS MP730 All-In-One InkJet
You can open up the device and look inside. You'll prob ably find a jammed peice of paper or a paper clip or some obstacle inside jamming either the rollers or the track for the print head, or both.
Nov 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Paper jam
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 10, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
PAPER JAM
Open your printer and check inside in all compartments where the paper goes thru. After that use some dust spray to eliminate all possible little pieces of paper.
Jan 23, 2009 | Canon SmartBase MP730 All-In-One InkJet...
I purchased a used MP730 from friend, she did not give me the manual
All the information for this machine is located at the Cannon website..
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=9035
Download the Users guide and read it, it has all the information you need. This site also has all the drivers needed as well.
It is also a good from time to time remove the ink cartridges and spray a bit of air to clean out the dust.
Oct 25, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Extra paper pulled
Some rubber lining or rollers is out of line, if you can fix that it may work properly.
Oct 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MP730 "carrige jam" error frequently
This error will generate when the printhead holder cannot move. This is usually due to a paper jam. Clear the jam (or whatever might be obstructing it) and then press "Resume". Do NOT try to move the printhead holder manually. As for cleaning your printer, here is the owners guide from Canon. http://alpha03u.c-wss.com/inc/ApplServlet?SV=WWUCA900 Download the last link on the page. Hope this helps. Good luck.
Jun 28, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Load paper and paper jam error msg
No solutions really. I have the same problem. I have a service manual. It takes a few hours to take it apart. I took out the ASF (automatic sheet feeder) unit out and cleaned it thoroughly, used compressed air to clean any sensors, and to no avail. It did absolutely nothing. The ASF unit is one of the last things you get to.....so it is a big pain. If you want the pages on taking it apart, feel free to email me at niedae AT iwon DOT com. Be sure to use tape to associate the screws with the various service parts. If you figure it out..please post your fix.
Mar 10, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
167 people viewed this question
old marine
old marine
