Question about Whirlpool RBD305PD Electric Double Oven
Our Whirlpool oven started beeping and the code read, E6 F2. We talked to a Whirlpool rep and he told we needed a new touchpad. We ordered a new touch pad and when we hooked it up, the code read E1 F2, none of the pads worked except you could hit bake and 350 would come on and you move the temperature up but not down and you couldn't hit start to turn it on. We looked at the control board it had some loose connections and one spot was discolored so we ordered a new control board. When the new touchpad and new control board were all hooked up, we still got the E1 F2 code. Can there be anything else wrong? Thank you for your help.
  • 15,935 Answers
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#@!
Posted on Oct 01, 2010
  • 84 Answers
An E6 F2 error code on these parts has always been due to the control board. These controllers can be repaired quickly and reliably at www.fixyourboard.com If buttons are not working or you get an F2-E0 or F2-E1 then it is the keypad
Posted on Nov 03, 2010
How to remove side panels on a whirlpool Gold double oven, in order to remove control panel. I would like to reconnect the control panel, it may reset the panel to work again
Hello Ms Jackson,
An E6-F2 is a very common control board failure. The control board in your appliance will need to be repaired or replaced.
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty. http://blog.fixyourboard.com/2015/08/20/gbd-rbd-whirlpool-oven-problems-causes-and-solutions/
I've also attached a link on how to remove your Whirlpool oven control board How to Remove Whirlpool Oven Control Board
Feb 10, 2017 | Whirlpool Ovens
Our oven read a problem # E6 F2 what that's mean?
The E6-F2 error code means that the control board thinks there is a problem with the cancel button on the touch pad. Sometimes its due to a loose connection from the ribbon cable on the touch pad. You can push cancel and clear it and if within 5 or under the error code returns the touchpad needs to be replaced. But first check/have the connection checked to make sure its tight. The way modern things work though is grand and Whirlpool say if after replacing touchpad the error code returns once again the clock/control board is what needs to be replaced.
Gene
Aug 11, 2011 | Whirlpool RBD305PD Electric Double Oven
Received E6 and F2 code. repair man replaced the control panel key padand it worked for a while. stopped working and got same codes E6 and F2. Repairman saw the control's behind the key pad needed to be...
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 15, 2011 | Whirlpool GBD307PR Electric Double Oven
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
I have a whirlpool oven which has an error code flashing "E6 F2" the display is coming and going
F2 is most likely the oven temperature sensor. I cant find any reference for E6
Sep 15, 2010 | Ovens
WHIRLPOOL GOLD DOUBLE OVEN BEEPING WILL GO BLANK THEN WILL SHOW E6 F2 TROUBLE CODE
Hi dear.Please do the following if you know what you are doing.According to your explanation,F2E6 code on whirlpool oven related with following: F2 - E6
I hope that solves your issue.Thanks.
Aug 28, 2010 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Mar 28, 2008 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool RBD305PD Electric Double Oven Logo
837 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
