Question about Whirlpool GB9SHKXL Bottom Freezer Refrigerator
How do you remove the light switch on a whirlpool refrigerator
I need to replace the light switch on whirlpool side by side refrigerator. Does the switch just pry out of the side. If so how?
THANKS
  • 333 Answers
The light switch just pops out. Take a butter knife or something of that sort and put it on on end of the switch and poush towards the center of the switch whilr prying it up. It should pop out. I hope this helps. Don't forget to rate my answer.
Posted on Feb 06, 2009
Whirlpool Side by Side refrigerator interior refrigeration section light glows orange and makes noise
Have you tried replacing the lamp to see if problem goes, is so then its probably coming from the door switch.
Nov 18, 2013 | Whirlpool Refrigerators
Refridgerator light quit working on 2003 whirlpool gold conguest side by side
Unplug your refrigerator and gently pry out the light switch and test the light switch for continuity. Most likely the light switch=> C3680310 Light Switch is defective or the=> W10134764 Light Socket Best way to test the switch is found HERE. If you have questions on testing I will be here or through my websites, Thanks, Sea Breeze
Adobe Reader X 10.1.3 Free Download
GX5FHTXVQ00_Parts_Manual
Jun 25, 2012 | Whirlpool White Gold 25 cu. ft. ENERGY...
HOW DO I TAKE OFF LIGHT BULB IN REGRIGERATOR SO I CAN CHANGE IT IT'S NOT UNSCREWING
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair centre that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Check this link if it helps:-
http://www.ehow.com/how_4856659_change-light-bulb-whirlpool-refrigerator.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Light Out
Either the door switch is broken or the light socket center connection tabs are bent too far in. Seeing as all the lights are out at the same time my money is on the door switch. It just pushes in and can be removed with a plastic putty blade.
Eric
Oct 29, 2009 | Whirlpool GS6SHEXNL Side by Side...
Refrigerator light out
Hi, Did you try the old bublb in a lamp to make sure the bulb was bad? Sometimes when you put a new bubl in, it feels like it goes all the way in. Try tightening the bulb again. Use a rag and grab the bukb with the palm of your hand a turn. I have been on many of these that just needed a little more turn even tho it felt tight.
I hope this helps. If this does not take care of the problem, remove the light switch and test it for continuity.
Please let ne know if I can assist you further.
Vic
Jun 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
switch of your refrigerator then try replacing the light that doesn't work then try to switch it back on. the light might be the cause of the noise. it might be grounded. replacing the light might reduce the noise then observed the noise for a week then if it still making noise that's the time for you to get a technician that could fix your refrigerator.hope it helped... send us a message for more concerns thank you...
Jun 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
HELP MY LIGHT DOES NOT WORK AND MY WIFE HAS CUT ME OFF UNTIL IT DOES
The problem is in the control board. A diode is shorting the relay, also has burned off trace. Looking for diode to replace as I write this.
Jan 01, 2008 | Whirlpool ED2FHEXN Side by Side...
RE- WHIRLPOOL NO FROST REFRIGERATOR NOT WORKINK NEEDS SOME HELP
whirlpool has a problem with the relayoverload thats plugged into the compressor. unplug the frig for about 5 min. then, while standing behind it plug it back in and listen. if you here a hum then a click, then you need to replace the relay overload. remove the back panel. the relay overload it plugged in on the left side of the compressor. very easy to replace
Nov 28, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool GB9SHKXL Bottom Freezer Refrigerator Logo
266 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
