Question about Samsung VR8460 VHS/S-VHS playback VCR
JVC CR-6060U Stuck in 'Search' mode
This machine had not been used in several years. I digitized one tape, and afterwards, I pressed the counter reset button. The machine went into rewind/search (tape wrapped around the head), and wouldn't stop, even after it reached the start of the tape. I managed to get the tape out, but the machine stays in this mode.
Any ideas?
    Genius:
  • 1,148 Answers
TAKE IT APART CHECK TO SEE IF ANYTHING IS STUCK,,TRY A JUNK TAPE ,,,,BLOW OUT ANY DUST ,,USE A HEAD CLEANER WITH ALCOHOL
Posted on May 15, 2009
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
My camcorder goes into safeguard mode EO3 when I try to clean it.
I have had the same problem with a different model JVC. I haven't been able to fix it yet, but there were a bunch of people on a different forum that were able to fix that error code quite simply. With a tape in the machine, flip the lever to eject the tape, then as soon as you hear the motor start to whir, quickly close the door.
It didn't help me, but like I said, several people reported that that action fixed the EO3 error.
Feb 01, 2009 | JVC GR-DVL505 Mini DV Digital Camcorder
JVC ¾? Umatic Model CR-6060U parts or alturnative
I used to repair these units and still own one. Each
one of the black side panels (control panel covers) is
held in place by four screws. After removing the
screws and control knobs, the right panel should come
right up. You may need to move the left hand panel
forward to clear the headphone jack before it can be
removed. From your description, it sounds like the
FF/play rubber tire is worn. After removing both side
panels, remove the cassette elevator. The elevator is
held in place by four screws. Two on each side of the
elevator. Pull the unit up, the FF/play and RR rubber
tires should now be clearly visable. Have you found a
video head yet?
Jul 29, 2008 | Televison & Video
JVC Digital Video Camera - model GR-D290
In the case no REEL FG is produced for 4 sec-onds
or more in the capstan rotation mode af-ter
loading was complete, the mechanism mode
is shifted to STOP with the pinch roller set off.
This error is defined as [E03].
However, no REEL EMG is detected in the
SLOW/STILL mode.
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of over-load
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
status.
Jun 03, 2008 | JVC GR-D290 Mini DV Digital Camcorder
MiniDV tape stuck inside
sounds like a defective cassette housing, but i have seen problems with jvc decks and camera when tdk or maxell tapes were used. the lids on these tapes seem to get stuck in the cassette housings in jvc equipment. jvc even recommends that tdk and maxell tapes be avoided.
May 24, 2008 | JVC BR-DV3000U DV/Mini DV VCR
JVC AV-48WP55
Many models of this time frame have an auto index function, and will alway record the pulse when entering record mode from "stop" or "pause". To prevent this unit from recording the pulse, try backspacing the tape, then press "Play", then press "Record" while play is engaged. Always works for me. Another thing you can try if you want the machine to ignore the index on previously recorded material, is to switch the index function to "Counter"; When FF or REW, the unit will look for the counter "0000" rather than the index pulse. ...Accordianman
Aug 17, 2007 | JVC HR-S9500 S-VHS VCR
Safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
Doesn't repond to buttons and stuck on rewind
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but one of the reel
Nov 29, 2005 | JVC HR-VP670 VHS VCR
Samsung VR8460 VHS/S-VHS playback VCR Logo
97 people viewed this question
Henry  Thomas
Henry Thomas
